:: Zobrazit téma - E71seriesGraphicChange
Jdi na stránku Předchozí  1, 2, 3, 4  Další
Odpovědět na téma    Obsah fóra -> Software
delpierwin
Založen: 27. 12. 2007
519.20 SMM
PříspěvekZaslal: čt leden 24, 2008 8:54 am    Předmět: Odpovědět s citátem
Ooops, i think that's the point Zeus, i use 450100 firmware it's Lg01. Okey i'll made my self then.
SiemensXP | My Blog
BenQ Siemens EL71 v45 Diamond Style
Siemens ME45 Standard
Siemens A70 Almost die -- dying
Siemens S57 v17 Standard
Siemens SX1 v15 Cristal 2+
Siemens M65 Windows 7 v1.1
Siemens S75 v47 Katie Meula Case
HTC Touch Pro - Timolol's WM6.5 Stock Like ROM
truhlik
elfmaster
elfmaster
Založen: 11. 08. 2004
8069.50 SMM
PříspěvekZaslal: čt leden 24, 2008 9:35 am    Předmět: Odpovědět s citátem
Zeu5 napsal:
Hello
I am an author of this program
sometimes I visit this forum and can read messages on english Smile
What you want to see in new version of the E71sGC?
so except
-searching for free place in FF, as in SPC3 for making GraphPatch
-full translation dialogues
that i try to add..
when i finish translating to English, i can add CZ language with anybody's help from this topic, i write there when it is necessary Wink
hi,
my suggestion: you should add support for x75 series & NewSgold series.
I think, this is really good soft and this support helps many people.
brgds
Motorola AMIO --> SL45i v56 tuned --> S75 v47 + FFS v40 + map v40 + Flash Patch
Svatky - 06
DApp - 055b
Elfpack.wz.cz Elfpack česky by truhlik Razz
http://sl45i.wz.cz/ SL45i patche
Zeu5
Založen: 30. 12. 2006
10.10 SMM
PříspěvekZaslal: čt leden 24, 2008 6:09 pm    Předmět: Odpovědět s citátem
truhlik napsal:
Yes, it is in my plans for the future
i want add x65series(and CX75, M75, C75 etc) and if s75 & sl75 have structure such as x65 they will be added too Wink
so i start research pictures structure in PITmaker, which support x65 and s75. you can download this programm from my site (www.skypiece.narod.ru). but PITmaker had many bugs Smile
delpierwin
519.20 SMM
PříspěvekZaslal: pá leden 25, 2008 10:12 am    Předmět: Odpovědět s citátem
Hello Zeus, why i couldn't found english drop down choice for language in the top right of it? Is there any download link for English language support?
SiemensXP | My Blog
Zeu5
10.10 SMM
PříspěvekZaslal: pá leden 25, 2008 1:05 pm    Předmět: Odpovědět s citátem
delpierwin napsal:
Use this URL for download always latest version Smile
Duku
uživatel roka 2008
uživatel roka 2008
Založen: 18. 12. 2004
Telefon: EL71v45
28.71 SMM
PříspěvekZaslal: pá leden 25, 2008 4:29 pm    Předmět: Odpovědět s citátem
Hi. Can you add support for Czech and Slovak chars in loading BMPs from folder?
kód:
á, ä, č, ď, é, ě, í, ľ, ĺ, ň, ó, ô, ř, ŕ, š, ť, ú, ů, ý, ž
>Daruj krv<
kozino
Založen: 04. 04. 2006
2156.42 SMM
PříspěvekZaslal: pá leden 25, 2008 4:53 pm    Předmět: Odpovědět s citátem
These are letters which Duku wrote. http://www.imghosting.eu/view.php?img=chars.bmp
thiagom
Založen: 15. 09. 2004
PříspěvekZaslal: pá leden 25, 2008 5:29 pm    Předmět: Odpovědět s citátem
Duku napsal:
kód:
Well, if you can add support for Portuguese Brazilian chars too...
"áÁ,àÀ,éÉ,êÊ,óÓ,íÍ,úÚ,îÎ,çÇ,ãÃ,õÕ,ûÛ.."etc
Zeu5
10.10 SMM
PříspěvekZaslal: pá leden 25, 2008 6:23 pm    Předmět: Odpovědět s citátem
hmm
if my prog open your fullflash then all pictures in all fonts may be changed..(if its size<=current PICture size)
put on some folder *.bmp files with necessary numbers and use "Load BMPs"
that all..
principle of the adding from folder - prog has trying open BMPs from 0001.bmp to maxNum picture in current font, if file named xxxx.bmp exists then it open and change current pic or not change (see above)
May be, I has not correct understood your request?..
Duku
uživatel roka 2008
uživatel roka 2008
Telefon: EL71v45
28.71 SMM
PříspěvekZaslal: pá leden 25, 2008 6:47 pm    Předmět: Odpovědět s citátem
I know in english only few words, but i try it Laughing Embarassed
For example "á" in FF has number 0161, but "á" from font2png has number 0225.
I know, change belike dont need E71seriesGC, but font2png....I just trying it Mr. Green
>Daruj krv<
Zeu5
10.10 SMM
PříspěvekZaslal: pá leden 25, 2008 10:06 pm    Předmět: Odpovědět s citátem
Duku napsal:
Yes, sGC not moreover here..
you need configure font2png
for example:
charsmod.ini
[RUSSIAN_CHARSET]
;верхний регистр
192=446
193=447
194=448
195=449
you must use -
[CZECH_CHARSET]
;uppercase
161=225
162=226
163=227
164=228
But font2png not have "CZECH_CHARSET", you need ask SilentDek for add it..but he has accidentally destroyed sources Laughing and not so will soon write new Sad
so..you can try leave "RUSSIAN_CHARSET", modify codes and choose RUSSIAN_CHARSET in program and press "START(BMP)". Good luck!
Zeu5
10.10 SMM
PříspěvekZaslal: ne leden 27, 2008 9:58 pm    Předmět: Odpovědět s citátem
update - 27.01.2008, E71seriesGC 0.1.790
+searching for free space in fullflash for graf. patches
+support png (necessary bend nconvert). Drop nconvert to sGC folder
+interface and code, possibility of the save settings
If you want to translate E71sGC on your national language download English LangFile
SiemensGraphicChanger Developer
screen
Sefinko
elfmaster
elfmaster
Založen: 23. 03. 2005
Bydliště: Strážske (Okolie) Telefon: CSL65v53 EL71v45 + 1GB Kingston (c) Benlux
6980.53 SMM
PříspěvekZaslal: ne leden 27, 2008 10:50 pm    Předmět: Odpovědět s citátem
2 Zeu5: Here is translate LangFile to Slovak: SLovak
2 Others:
Ak niekto ma cas tak sa mrknite ci je to prelozene dobre, lebo ja teraz nemam velmi cas takze to bolo narychlo...
delpierwin
519.20 SMM
PříspěvekZaslal: po leden 28, 2008 2:51 am    Předmět: Odpovědět s citátem
Zeu5 napsal:
delpierwin napsal:
Wow thanks a bunch Zeus Very Happy
SiemensXP | My Blog
delpierwin
519.20 SMM
PříspěvekZaslal: út únor 12, 2008 11:01 am    Předmět: Odpovědět s citátem
Looks like link was down Crying or Very sad
EDIT: Sorry, it's working again now... Very Happy
SiemensXP | My Blog
Odpovědět na téma    Obsah fóra -> Software Časy uváděny v GMT + 1 hodina
Strana 3 z 4
