delpierwin badatel
Založen: 27. 12. 2007 Příspěvky: 146 Bydliště: Sukabumi, Republic of Indonesia
519.20 SMM
Zaslal: čt leden 24, 2008 2:43 am Předmět: Crashed by Elf Application |
Hello,
Just want to share and discuss, a couple day ago till now, i'm just confused because my EL71 always crash everytime i turn it off or reboot it. This are p-exit info :
This problem always occur, when i'm activate FastRun2, when FastRun2 active then i turn off or reboot, handset always sounds beep then off crasehd.
On p-exit info, it said CEPname : MMI, then i try some steps :
I apply Higher MMI Prio and Disable MMI, but it's not helping, then i undo them all.
I re-format Micro SD, then copy Zbin folder again, but it's still crash.
Increasing PNG cache to 200, still crashed
Try another FastRun2.elf file, not helping
And last, downgrade to ElfPack 2.3 (from Elfpack 2.31), but again still crashed.
I'm sure my last hope is how to translate those p-exit info, is anyone had reference about translating p-exit information, or i just can try another solving method?
Well it's all matter i had, please help me, thank You. _________________ SiemensXP | My Blog
BenQ Siemens EL71 v45 Diamond Style
Siemens ME45 Standard
Siemens A70 Almost die -- dying
Siemens S57 v17 Standard
Siemens SX1 v15 Cristal 2+
Siemens M65 Windows 7 v1.1
Siemens S75 v47 Katie Meula Case
HTC Touch Pro - Timolol's WM6.5 Stock Like ROM |
thiagom začátečník
Založen: 15. 09. 2004 Příspěvky: 38 Bydliště: Rio de Janeiro - Brasil
Zaslal: čt leden 24, 2008 3:31 am Předmět: |
I have this problem too.. Really, i dont know that causes, but, i know that is an incompatibillity with ExtraInfo..
Make a test: Try to disable Extrainfo then Running FastRun2..Note that you will can Reboot/Shutdown normally..Right ?
If you run Extrainfo, then shutdown/reboot with FastRun2 active, phone crashes..
I have already show this too both authors,(Extrainfo (miha_r), and FastRun(The_Zen/kluchnik), but nothing solution yet..
Try this then post results..
Regards.. |
delpierwin badatel
519.20 SMM
Zaslal: čt leden 24, 2008 3:45 am Předmět: |
Wow, yeah You were right Thiagom, after i read Your experiment, then i delete Extrainfo and activate FastRun2. Now i can turnoff or reboot handset without any crash. This two elf application couldn't run together, that's the fact.
By the way, have You try another version of Extrainfo? Like v1.83 or newer? Cause i try to change and try all version of FastRun2, there are no difference... _________________ SiemensXP | My Blog
thiagom začátečník
Zaslal: čt leden 24, 2008 4:47 am Předmět: |
Well, when i talking to Miha_r about this trouble, he tell me thats are an version of FastRun2 that worked is...:
"...last version of fastrun2 which works properly with extrainfo is version which was made in august(22kb size).."
try this: http://forum.siemens-club.org/attachs.php?action=getfile&attachID=18844
Post results.. |
delpierwin badatel
519.20 SMM
Zaslal: čt leden 24, 2008 5:42 am Předmět: |
I allready try it Thiagom, Yes it's really work, but looks this cap Thiagom :
It's made for 132x176 resolution, i can't set panel length above 176, and there is no option for icons size resolution. Is there any other version Thiagom? _________________ SiemensXP | My Blog
thiagom začátečník
delpierwin badatel
519.20 SMM
Zaslal: pá leden 25, 2008 3:43 am Předmět: |
Still crashed Thiagom, i also try other one in the same page :
FastRun4
21.01.08
And then, phone couldn't be turn off or reboot, and in a couple seconds beeppp
I should remove the battery now
Btw, i also experience whether Extrainfo.dis were conflict too with extrainfo.elf _________________ SiemensXP | My Blog
delpierwin badatel
519.20 SMM
Zaslal: pá únor 01, 2008 2:57 am Předmět: |
Lately i've solve this problem, before i had this problem i put all PNG's image on MicroSD, then i make a little change, move some (i move font image) to drive 2:Config, then crash happening rarely. _________________ SiemensXP | My Blog
thiagom začátečník
Zaslal: ne únor 03, 2008 10:49 pm Předmět: |
Good! I have my fonts on MMC too, i will try to move it to Config, then i post results...
Regards |
delpierwin badatel
519.20 SMM
Zaslal: po únor 04, 2008 8:27 am Předmět: |
Okey Thiagom, success on You _________________ SiemensXP | My Blog
thiagom začátečník
Zaslal: po únor 04, 2008 11:51 pm Předmět: |
Very strange, my fonts are already in Config drive, and this issue not solved...
I will try to make others tests like these later...Then, i will post results.. |
delpierwin badatel
519.20 SMM
Zaslal: st únor 06, 2008 5:07 am Předmět: |
Hmm, I said rarely not solved all Thiagom, nerow said other alternative remove dispalyshooter from daemons, if You had any. But i don't have it since i had this annoying things. _________________ SiemensXP | My Blog
