huteusz kolemjdoucí
Založen: 29. 08. 2007 Příspěvky: 13 Bydliště: Krakow-Polska
19.00 SMM
Zaslal: so únor 09, 2008 7:55 pm Předmět: Xbz Editing |
Hello, i've got an soft in XBZ. Is there any way to edit it, and put into phone as a normal SWUP, like a update?
I want to switch langpack in xbz file between 01 and 91 using tool. I can't do it without x65flasher since i haven't service cable and bootkey generated. |
Gwin čestný člen
0.84 SMM
Zaslal: so únor 09, 2008 9:07 pm Předmět: |
Are you sure that it is XBZ? Isn't it XBI? _________________ Alcatel 301 => Alcatel 301 => Nokia 3210 => Nokia 3310 => Nokia 3410 => Siemens SX1 => Nokia E51-1 => HTC TyTN II => Samsung GT-I8190
huteusz kolemjdoucí
19.00 SMM
Zaslal: ne únor 10, 2008 5:01 pm Předmět: |
Yes, it's XBZ, not XBI.
I want to edit 450100 to make 459100 from it. I have XBZ and FBK with Langpack. Probably it can be done using hex editor.
Any ideas? It is possible?
Thanks
phone = BS e71 |
huteusz kolemjdoucí
19.00 SMM
Zaslal: po březen 10, 2008 7:06 pm Předmět: |
And what about this?
I heard that there are some problems with CRC-checking... |
