:: Zobrazit téma - USB to COM
USB to COM
Odpovědět na téma    Obsah fóra -> Non Czech Languages Here
hotter
Založen: 04. 12. 2004
Telefon: M55
47264.96 SMM
PříspěvekZaslal: pá říjen 30, 2009 8:16 pm    Předmět: USB to COM Odpovědět s citátem
My new laptop doesnt have a com port, but I need it to patch my M55, so I got "USB to COM" cable, but it doesnt want to work. Is it possible to make it work with M55 patching cable? How? Maybe someone tried such cable and know? Confused
Maybe such cables are just for old printers? Mr. Green
N3310 -> M55sw91 + Hotter tuning + 3.75mb -> CXV70sw50 + Hotter MacOS tuning + 11.27mb + blue diods + winamp + headphones -> SX1sw15 + Hotter tuning + 2gb -> Asus P525 + Vista tuning + 2gb -> N3310 + Hotter tuning + M55sw91 + 4.14mb + patches + PSP -> M55 + Patches + DCA-510usb
yaqwsx
Založen: 12. 12. 2005
209083.66 SMM
PříspěvekZaslal: pá říjen 30, 2009 9:38 pm    Předmět: Odpovědět s citátem
Have you tried the cable with another HW? For example printer or something like this. Because it can be wrong driver or someting and cable does't work for all.
Another solution: Use a docking station for NTB. Docking stations usually have COM port. With this port it will work for 100 %.
JFGI - Just Fuckin' Google It
hotter
Telefon: M55
47264.96 SMM
PříspěvekZaslal: so říjen 31, 2009 8:17 am    Předmět: Odpovědět s citátem
I think I dont have any HW with COM port to try... I installed some kind of drivers, maybe I need to configure them?
Options screenshot
(I tried it on windows 7 and windows XP)
cyber-j
mecenáš
mecenáš
Založen: 16. 10. 2004
3.28 SMM
Příspěvky na SM: 1460,-
PříspěvekZaslal: so říjen 31, 2009 10:28 am    Předmět: Odpovědět s citátem
I think the driver is OK. Try to set lower settings, as it is writen, it is better for correction connect problems. Maybe it will help.
M35->ME45i -> M65@CX70 -> M75 ->
Utano Barrier T180 -> Cat B15
hotter
Telefon: M55
47264.96 SMM
PříspěvekZaslal: so říjen 31, 2009 1:19 pm    Předmět: Odpovědět s citátem
Nope, not helping Sad any other ideas?
Is there x55 usb cables for patching?
hotter
Telefon: M55
47264.96 SMM
PříspěvekZaslal: po listopad 02, 2009 12:13 am    Předmět: Odpovědět s citátem
Would such cable work with M55 patching:
or this
? Rolling Eyes
found it here http://sx1.oslik.ru/werefox/circuit/cable55.html
hotter
Telefon: M55
47264.96 SMM
PříspěvekZaslal: st listopad 25, 2009 7:42 pm    Předmět: Odpovědět s citátem
I got rid of my "made in china" usb to com cable, so I could buy a new one but only if that cable would truly work with DCA-510com cable, anybody know such cable?
Or any one have scheme of x55 usb cable for patching/data transfering? Rolling Eyes
hotter
Telefon: M55
47264.96 SMM
PříspěvekZaslal: út květen 04, 2010 5:37 pm    Předmět: Odpovědět s citátem
hotter napsal:
Just made usb cable by this schema. Works good on m55 and cx70, shows DCA-510! Smile
Soldering was really hard because chip is only 5x5mm, but I made it! Smile
Odpovědět na téma    Obsah fóra -> Non Czech Languages Here Časy uváděny v GMT + 1 hodina
