:: Zobrazit téma - S88 Display
S88 Display
Odpovědět na téma    Obsah fóra -> Třída S
pilina
Založen: 07. 02. 2005
46.90 SMM
PříspěvekZaslal: st listopad 17, 2010 12:37 pm    Předmět: S88 Display Odpovědět s citátem
Otazka nemamte nekdo display na S88 na prodej nebo aspon kterej by tam sel a navod na rozebrani diky moc za prispevky
Založen: 01. 08. 2008
Telefon: EF81
129512.00 SMM
PříspěvekZaslal: st listopad 17, 2010 3:22 pm    Předmět: Odpovědět s citátem
mario_liptov napsal:
S88 assy antenna cover black HYPB1A cosmic black 19 50,00
S88 assy battery cover black 17 25,00
S88 assy front case HYPB1A cosmic black 4 100,00
S88 assy rear case hyperion B1 19 25,00
S88 camera module 10 100,00
S88 cap joystick 19 15,00
S88 CONNECTOR 20 15,00
S88 connector AXK7L30227 20 10,00
S88 connector BF1-015 10 10,00
S88 connector SKT20P D,4 20 10,00
S88 dome keypad SUS301
S88 fabric conduct DSC 10 2,00
S88 fabric conduct LCM BTB 10 2,00
S88 FPC DSC HYPB1A flex 20 50,00
S88 FPC flash 10P 20 90,00
S88 fpc keypad v4 10 80,00
S88 holder DSC 10 10,00
S88 IC ANA MIC2291-34Y 20 15,00
S88 IC ANA WM8755210549 20 50,00
S88 IC Logic SN74AVC24T 20 25,00
S88 IC MCU SH7315 20 100,00
S88 key shutter ABS+R HYPB1A 20 10,00
S88 keypad black 9 30,00
S88 lens main cosmic black 10 25,00
S88 mylar simcard pet 10 2,00
S88 OLED 2,0 HO20HD01 V1 6 100,00
S88 rubber joystick cap 10 3,00
S88 rubber microphone 20 2,00
S88 screw tap PH M1.6*3L 18 2,00
S88 support keypad 10 5,00
S88 SWI EVQQ7GA50 20 20,00
S88/CL71 connector memory 10 20,00
S88/CL71/E61/EF51 IC Asic D751992AZH 15 95,00
S88/CL71/E61/EF51 IC IR XCVR Receiver 10 10,00
S88/CL71/E61/M580/EF51 OSCCRYST 32,768 K12,5PF20PPM 10 10,00
S88/CL71/M580 IC PWR AMP Amplifier 10 10,00
S88/E61 vibra-alert 10 10,00
S88/E61/CL71/EF51 I/O connector 5 10,00
S88/EF51 IC BC 313141A07-IXF 20 40,00
S88/EF51 receiver SDRP0615AJ01-G 10 15,00
S88/EF51 screw TAP PH M1,6*5L 39 1,00
S88/EF51 speaker D18 0,5W 20 20,00
S88/EF51/E61 connector SIM 20 10,00
S88/EL71/E61/CL71/M580/EF51 jack DC pwr 10 10,00
S88/M580 battery conector 10 10,00
S88/M580/CL71/EF51 antenny conector 10 2,00
Display by mohl být k mání ZDE. Řekl bych že je to součástka, kterou jsem zvýraznil tučně. Think Ale nejsem si jistý, mario_liptov bude vědět...
Založen: 09. 11. 2004
14311.82 SMM
PříspěvekZaslal: st listopad 17, 2010 4:34 pm    Předmět: Odpovědět s citátem
Nie je nič jednoduchšie, ako si objednať náhradný diel cez SZ (displej by určite mal mať) a mario_liptov zvykne odpovedať veľmi rýchlo Angel
Odpovědět na téma    Obsah fóra -> Třída S Časy uváděny v GMT + 1 hodina
