stav1988 kolemjdoucí
Založen: 05. 05. 2011 Příspěvky: 2
30.46 SMM
Zaslal: pá květen 13, 2011 11:56 am Předmět: Siemens SP65 |
1. What software i have to use for transfer music, movies, pictures, java, etc. and how? It work on windows 7?
2. The difference between SP65 and S65 is only the camera? otherwise have the same characteristics, ex: processor speed, supports the same extensions, etc?
3. I found here that can put mp3s on it http://sandstormrs.proboards.com/index.cgi...&thread=588 someone succeeded? can even tell me what program i need, where i download ELF? can explain me step by step how?
4. I have 48 firmware on it, the last is 50, how to update it?
5 .I need the original cable to update the firmware phone?
Thanks verry much!!! my SP62 is new i want to join it. |
NoviS řád zlaté antény
Založen: 01. 08. 2008 Příspěvky: 857 Bydliště: Praha Telefon: EF81 144510.50 SMM
Příspěvky na SM: 115,- |
Zaslal: pá květen 13, 2011 8:52 pm Předmět: |
1) You can transfer everything via memory card reader, i think every SD card reader supports (RS-)MMC.
2) Yes, i think that camera is the only difference. But if you think for example patches, you have to find patches which were made especially for your phone and FW version.
3) I don´t know, I hope that somebody else will help you with this. Tutorial how to play MP3s on x65 is HERE.
4) It is simple, instructions are HERE.
5) No, you don´t need original cable for FW update, but it has to be marked as DCA-510. You may see what type of cable you have after pressing *#06# -> more, under Acc. plugged in:... _________________ A52 -> M65† -> SXG75† -> SK65 -> S75 -> SX1 -> SK65 + S75 -> SL75, SK65, S68, S65, EF81... prostě pořád nějaký SIEMENS
->MOJE SBÍRKA<- |
30.46 SMM
Zaslal: so květen 14, 2011 2:00 pm Předmět: |
My cable model is KQ-U8A when i press *#06* Acc says... none, that i think my cable is not support. what to do now ?
you have an id messenger to discuss? |
Zaslal: út květen 17, 2011 10:31 pm Předmět: |
To find what kind of cable do you have is neccessary to plug the cable into both computer and phone... maybe the mistake is here .
As a software you may try SiMoCo (from here), i have it already installed on Win7.
I have only ICQ, but, however, I wrote here everything I know . _________________ A52 -> M65† -> SXG75† -> SK65 -> S75 -> SX1 -> SK65 + S75 -> SL75, SK65, S68, S65, EF81... prostě pořád nějaký SIEMENS
->MOJE SBÍRKA<- |
