eboy442000 kolemjdoucí
Založen: 06. 01. 2012 Příspěvky: 2
26.04 SMM
Zaslal: pá leden 06, 2012 2:36 pm Předmět: EDGE connection problem happened to all EDGE models |
Hi, 1st post here from probably the only user of Siemens mobile in Hong Kong.
I use Siemens mobile as a modem to connect the computer to internet, but I find out that whenever the connection speed is over 160kb/s the phone stop responding in 1-5mins.
I have tried Siemens EDGE models s75, SL71, EL71, C81. All are having the same problem. Does anyone have a solution? Thank you!!!
I have search throught the internet and cannot find a solution. |
stano.mania siemensmaniak
14311.82 SMM
Příspěvky na SM: 160,- |
Zaslal: pá leden 06, 2012 10:01 pm Předmět: |
Years ago I have used Siemens modem of mobiles for connections PC to internet. I have solved some similar problem with service center, that consulted it with Siemens Center, but I newer knew why modem of mobile was asleep - stoped. I did some special logs.
I used modem by Bluetooth and I recovered that I set "recovery" interval on the site of PC to minimum = 1 min., default was 10 min, so this problem was solved. But each modem may stop after certain time, so I setup that PC starts automatically after 1-3 sec when modem stoped. |
26.04 SMM
Zaslal: so leden 07, 2012 5:22 am Předmět: |
Thank you so much for your reply. Where can i set the recovery time?
My Siemens modem not only stop responding, it hangs, and i have to take out the battery and switch on the phone again. Did you have the same problem? _________________ Probably the only Siemens mobile left in Hong Kong.
AF51
CX65, C81, CF110
EF81, EF91
M65
s35, S45, S65, SK65, S75, SXG75, s68, s81
SL75, SF71, SL91
SX66
P51 |
