trinium kolemjdoucí
Založen: 20. 07. 2010 Příspěvky: 1
19.62 SMM
Zaslal: po červenec 23, 2012 8:01 pm Předmět: Pach for Siemens CX75 serch |
Hello,
i serching a v_klay pach for siemens cx75v13, not a any pach, but pach for
turn backlight always on in java midlets, or pach for option in options menu
for toggle backlight (always on / normal mode).
It not must be a simple pach, meybe something for master pach, api or library? then if can sey with of function in master pach is needed
(only if know).
Subject to crash or for next generation
I use a 'change illumination turn off timer v2', and for menus & list set value to 0x00 and i have backlight alweys on in menus and in java, form menus is autoback to mainscrean then backlight turn off. From java nota autoback.  |
