:: View topic - C35i vs. PC
C35i vs. PC
Reply to topic     Forum Index -> x62 a starší řady -> x35, x25 a starší
Mavi
PostPosted: Wed Feb 09, 2005 11:51 am    Post subject: C35i vs. PC Reply with quote
Mam Siemens C35i , a kdyz se ho pokusim spojit s kompem , tak muzu akorat pres komp zamknout klavesnici ,a zmenit melodii Crying or Very sad , poradte mi nekdo , prosim Angel , nemam orig. kabl , dix , Mavi
Mavi
PostPosted: Wed Feb 09, 2005 11:52 am    Post subject: xakru , sry Reply with quote
Sry moc , sem zvikley , jen odepisovat na otazky , a tak kvuli tomu sem dal omylem nadpis Mavi , moc SRY , omlouvam se moc moc moc
Sirus
7910.50 SMM
PostPosted: Wed Feb 09, 2005 12:15 pm    Post subject: Reply with quote
Tak som ti to trochu poopravil.
PostPosted: Wed Feb 09, 2005 12:45 pm    Post subject: Re: C35i vs. PC Reply with quote
A co by si viac chcel? wink
Mavi
PostPosted: Wed Feb 09, 2005 2:17 pm    Post subject: Re: C35i vs. PC Reply with quote
Mno treba , posilat loga , jaxe vsude pise , atd , nemyslel sem , ze se da teda jen prepinat melodije , a zamykat klavesy Rolling Eyes Laughing Rolling Eyes
Bonfire
Phone: HTC HD2
9259.32 SMM
PostPosted: Wed Feb 09, 2005 7:44 pm    Post subject: Reply with quote
zalezi na programu... na sem kdysi pouzival nejaky sx35 nebo tak nejak a tam logo zmenit slo...
Koupím Siemens, který nemám.
PostPosted: Thu Feb 10, 2005 9:13 am    Post subject: Reply with quote
S S25atonce mozes nahrat logo,melodiu aj telefon ciastocne ovladat z compu.
Haldy
698.10 SMM
PostPosted: Thu Feb 10, 2005 2:39 pm    Post subject: Re: C35i vs. PC Reply with quote
Pouzij SiMoCo (kdysi davno Sx35_Cz) ten by mel zvladnout vsechno Smile .
Mobilní historie:
Dancall => C35i@M35i => ME45@S45i => A55,A57@C55 => C65 => M75 (všechny Patchované) => E-Ten Glofish X500 (WM6 lite)
Nerve_Toxin
PostPosted: Fri Feb 11, 2005 10:12 am    Post subject: Reply with quote
No SiMoCo je placenej, já myslím, že stačí ten Sx35CZ, tam akorát musíš jako registraci zaslat pohled 8)
(No jako nemusíš, ale slušnost je slušnost...)
Siemens is the best
C35i fw18+patche+t9CZ->MT50 fw18@242KB flex+patche->M55 Palladium fw11@3,6MB flex+patche->CX70 fw43
Mr.Ferda
(člen klubu SM)<br>pisatel
PostPosted: Fri Feb 11, 2005 9:11 pm    Post subject: Reply with quote
no v podstate lze pouzit kterykoliv SW pro Siemensy. Co mam Odskouseno tak jsou vetsinou spetne kompatibilni takze lze udelat vse potrebne. Zaloha seznamu jak na SIM tak v telefonu, nahrat jednu melodii (vice se tam nevleze) Pozalohovat a upravovat kalendar, prace s SMS a to vcetne odesilani a prijmu EMS, Nahrat LOGO, synchronizovat cas s PC a dalsi(Z klavesnice mobilu nelze vlozit do seznamu diakritiku ale pomoci SiMoCo to lze a telefon to umi zobrazit). Hadam ze Sx35CZ je na vetsimu postacujici. Osobne bych ale doporucil tu minimalni investici do ceskeho SiMoCo ktery je opravdu dobry a jak jsem dnes zjistil tak dokaze v nekterych funkcich komumikovat i s Nokii a SonyEricssonem.
Jen jeste mala zajimavost. Pokud na S35i poslete pres IrDA cernobile LOGO (a nemusi byt presne v rozliseni 101x43) a nebo jednohlese MID tak telefon jej umi pouzit a ulozi ho do pameti. Odskouseno z pomoci odeslani z SL45i. Predpokladam ze to lze z kazdeho Siemense z IrDA ale nezkousel jsem to.
Přeji hezký a úspěšný den.
S6/S10A/S25/S+M+C35/SL45->SL45i/S+M55/C62/S65/SX1 az nouze N3650, N6600, a ted N70. Radu z nich pouzivam dodnes.
Navic ted trápim bratrovu M65+N70, N7710, MDA Vario, K750i. :-)
Mr.Ferda
PostPosted: Fri Feb 11, 2005 9:21 pm    Post subject: Re: C35i vs. PC Reply with quote
No tak kdysi byl SX35Expplorer (Muze se to plest z Sx35CZ a jeho naslednou verzi Sx45CZ) ale byla i verze pro Nokii, tusim ze 7110, pomoci jehoz slo odesilat z Simense LOGO na Nokii. Predem upozornuji ze pouze odesilat, Siemens totiz neumi tento protokol prijmout. Nikdy jej , pokud vim, do svych pristroju neimplementoval. Byly i programky v MS-DOS ktere delaly totez ale o tom jsem pouze cetl v konferenci nebo na mobilmanii.cz ci mobil.cz , presne uz ale nevim, je to jiz hodne spet.
Mr.Ferda
PostPosted: Fri Feb 11, 2005 9:26 pm    Post subject: Reply with quote
SORRY tohle do tematu o C35i nepatri. Omlouvam se.
Reply to topic     Forum Index -> x62 a starší řady -> x35, x25 a starší All times are GMT + 1 Hour
