fchury kolemjdoucí
Založen: 28. 06. 2004 Příspěvky: 6
Zaslal: čt červenec 29, 2004 10:18 pm Předmět: patch na 1,88MB |
Jsem sice v této oblasti ješte začátečník, nicméně na stránkách v_klaye jsem našel patch na další zvětšení paměti. Prosím experty siemensmanie o prozkoumání.
;S55v20 - Óâĺëč÷ĺíčĺ ôëĺęń-ďŕě˙ňč v4 (1,88Mb).
;S55v20 - Increase Flex-memory v4 (1,88Mb).
;(c) avkiev 10.06.2004, improvement by (c) kay 30.06.2004
;Thanks to chaos, Sinclair
1. Backup
1.1. Use V_Klay 2.6 - http://www.vi-soft.com.ua/index_e.htm
1.2. Download your fubu.
1.3. Download all files by help DES.
2. Undo old patches
2.1. Undo previous versions of this parch.
2.2. Undo patch "Moving T9".
3. Moving T9
3.1. Download T9 base with one english language. http://forum.allsiemens.com/download.php?id=1670
3.2. Run V_Klay, choose "Flasher", open T9 base with english language.
3.3. Set: FromAddress=3C0000, Size=020000, UseFromOffset=000000.
3.4. Press "Write Memory", press "Yes".
4. Cutting and transfer langpack.
4.1. Cut langpack to 1 or 2 or 3 languages (it's size should be not more than 192K).
Or use this archive http://avkiev.siemens-club.ru/Siemens/Patches/IncFlex/S55lg91-EnRu.rar
4.2. Open binary langpack-file in V_Klay-Flasher.
4.3. Set: Address=0D0000, size don't change, UseFromOffset=0.
4.4. Press "Write Memory", press "Yes".
5. Transfer EELITE
5.1. Open your fubu (point 1.2) by help WinHex.
5.2. Save area BE0000-BEFFFF as new file. Its size must be 65536 bytes.
5.3. Open this file by help WinHex.
5.4. Press Ctrl-Alt-H (Replace Hex Values).
5.5. Check on "Replace all", "Use as wildcard", "3F", "All".
5.6. Set SearchFor=F03F3F3F3F3FFE3F3F3F3FF0, ReplaceWith=F03F3F3F3F3FF63F3F3F3FF0. Press Ok. Press Ok.
5.7. Press Ctrl-Alt-H (Replace Hex Values).
5.8. Set SearchFor=FC3F3F3F3F3FFE3F3F3F3FFC, ReplaceWith=FC3F3F3F3F3FF63F3F3F3FFC. Press Ok. Press Ok.
5.9. Save this file with new name.
5.10.Open this file in V_Klay-Flasher.
5.11. Set: Address=B60000, size don't change, UseFromOffset=0.
5.12. Press "Write Memory", press "Yes".
6. Apply patch below.
7. Turn on the phone, wait while memory will formatted.
8. Upload to the phone all files, which were downloaded in point 1.3.
9. Enjoy disk 1,88Mb.
PS. If something wrong - just restore your phone from backup (point 1.2).
PPS. New addresses: langpack: 0D0000-0FFFFF, T9: 3C0000-3DFFFF, EEPROM: B60000-B6FFFF and BF0000-BFFFFF.
1AFEFA: 1000000001009A3E6B01 10000000020000308601
1B3E74: 03 01
#pragma enable old_equal_ff
21B000: 0200,70,308601
21B006: 0200,7C,308601
21B00C: 0200,88,308601
21B012: 0200,94,308601
21B018: 0200,A0,308601
21B01E: 0200,AC,308601
21B024: 0200,B8,308601
21B02A: 0200,C4,308601
21B030: 0200,D0,308601
21B036: 0200,DC,308601
21B03C: 0200,E8,308601
21B042: 0200,F4,308601
21B048: 0200,00,318601
21B04E: 0200,0C,318601
21B054: 0200,18,318601
21B05A: 0200,24,318601
21B070: 0000,AC,004000
21B076: 0000,AD,004000
21B07C: 0000,AE,004000
21B082: 0000,AF,004000
21B088: 0000,B0,004000
21B08E: 0000,B1,004000
21B094: 0000,B2,004000
21B09A: 0000,B3,004000
21B0A0: 0000,B4,004000
21B0A6: 0000,B5,004000
21B0AC: 0000,B6,004000
21B0B2: 0000,B7,004000
21B0B8: 0000,B8,004000
21B0BE: 0000,B9,004000
21B0C4: 0000,BA,004000
21B0CA: 0000,BB,004000
21B0D0: 0000,88,004000
21B0D6: 0000,89,004000
21B0DC: 0000,8A,004000
21B0E2: 0000,8B,004000
21B0E8: 0000,F0,004000
21B0EE: 0000,F1,004000
21B0F4: 0000,F2,004000
21B0FA: 0000,F3,004000
21B100: 0000,F4,004000
21B106: 0000,F5,004000
21B10C: 0000,FD,004000
21B112: 0000,FE,004000
21B118: 0000,BD,004000
21B11E: 0000,BE,004000
21B124: 0000,7E,004000
21B12A: 0000,7F,004000
#pragma disable old_equal_ff
#pragma disable warn_no_old_on_apply
6C0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
6D0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
6E0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
6F0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
700080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
710080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
720080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
730080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
740080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
750080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
760080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
770080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
780080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
790080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
7A0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
7B0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
480080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
490080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
4A0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
4B0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
B00080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
B10080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
B20080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
B30080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
B40080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
B50080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
BD0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
BE0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
7D0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
7E0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
3E0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
3F0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
#pragma enable warn_no_old_on_apply
5E00A0: 8800 7C00 ; Transfer T9 from 480000 to 3C0000
5E001C: 2002 F001
5E002A: 2002 F001
5E004A: 2002 F001
5E005A: 2002 F001
5E034E: 2002 F001
5E035C: 2002 F001
27F5DA: C003 3401 ; Transfer Langpack from B00000 to 0D0000
27F5F2: C003 3401
27F90E: C003 3401
27F91E: C003 3401
27F92E: C003 3401
27F97C: C003 3401
27F984: C003 3401
27F9B6: C003 3401
27F9D2: C003 3401
27F9DA: C003 3401
27F9EC: C003 3401
27F9F0: C003 3401
27FA26: C003 3401
27FA4C: C003 3401
27FA54: C003 3401
27FAAC: C003 3401
27FC26: C003 3401
27FC34: C003 3401
27FC82: C003 3401
1B3F28: FE F6 ; Transfer EELITE from BE0000 to B60000 |
ghost_z_kca věrný diskusník
2065.50 SMM
Zaslal: čt červenec 29, 2004 10:38 pm Předmět: |
uz som to testoval, postup je taky isty ako pri 1.71M, ak mas urobeny eelite, mozes ho pouzit, je rovnaky, ale po rozsireni flex je tel. nefunkcny. bolo treba vratit zalohu fullflashu. chvylu to bolo aj tu na stranke, ale hanni to potom stiahol |
ScanX kolemjdoucí
Založen: 08. 09. 2004 Příspěvky: 1
Zaslal: st září 08, 2004 11:18 pm Předmět: |
Ahoj, neudelal uz nekdo verzi jen s ceskym menu a ceskou T9? To by se ta pamet treba dostala i na 2 MB. Kdo tomu rozumi, zkuste to. Diky |
Jabloncik kolemjdoucí
Založen: 27. 09. 2004 Příspěvky: 3
Zaslal: st září 29, 2004 7:53 am Předmět: |
Margo napsal: | Tak jsem skoušel flashnout S55 fw.91 na 1,58 MB a nešlo to. Problém byl při instalaci incflex2.vkp, během instalaci v V_Klay mi nahlásilo ňákou chybu. Je pozoruhodné, že při použití fw. 90 to jde. Další informace co jsem pochytil během používání S55 je, že při používání fw.90 šli v podstatě všechny patsche dělané pro fw. 20, nevím proč to nejde v fw91 (napřk. Supernet2). Dále by mne zajímalo jaký je rozdíl mezi fw.90 a fw91. Je nutné ho instalovat. (myslím fw.91).
Toš robky a chlopi poraďte. | 8)
Pri S55 je postup na 1,58MB taky isty len v subore incflex2.vkp zmen prve dva riadky
Sw20
1AFEFA: 1000000001009A3E6B01 0E000000020000308601
1B3E74: 03 01
Sw91
1AFF06: 100000000100A63E6B01 0E000000020000308601
1B3E82: 03 01 |
cemak kolemjdoucí
Založen: 24. 10. 2004 Příspěvky: 1
Zaslal: so leden 01, 2005 9:05 pm Předmět: |
[quote="KDante"]Lidicky vazne nevite, proc to porad pri pokusu o zapis pise The Offset of the Buffer cannot be greater than the Size of the Buffer.
Neni mozny to nejak obejit? Ja jsem uz hrozne zvyklej na T9 a bez ni uz ted tri dny upim.
Treba takto:?
Z adresy:0x7C0000
Velkost:0x040000
Pouzit z Offsetu:0x000000[/quote]
Pro vsechny, kdo narazi na tuhle chybu, tak staci jen v programu V_klay nacitat fullflash tlacitkem "Otevrit soubor" nad tlacitkem "Zapsat do pameti tel." pak to jede uplne v pohode, sam jsem se stim ted hezkou chvili pral
cemak
S55 fw20 1,58MB |
tacudek začátečník
Založen: 03. 01. 2005 Příspěvky: 32 Bydliště: brno
Zaslal: st leden 05, 2005 4:37 pm Předmět: |
Na jakej Fw to funguje zkoušel sem to na 91 a nefungovaloto ha sem špatně čet _________________ Bosh > Sagem > Alcatel 501 >S55 Fw 91+ 3x patch
www.tacudek.com :p
tacudek začátečník
Zaslal: st leden 05, 2005 6:28 pm Předmět: Problem 1,53MB :( |
Všecho sem udělal podle návodu ale nejede mi T9 mam S55 Fw 91 _________________ Bosh > Sagem > Alcatel 501 >S55 Fw 91+ 3x patch
www.tacudek.com :p
Lasius kolemjdoucí
Založen: 04. 01. 2005 Příspěvky: 4
Zaslal: st leden 05, 2005 8:20 pm Předmět: Re: Problem 1,53MB :( |
tacudek napsal: | Všecho sem udělal podle návodu ale nejede mi T9 mam S55 Fw 91 |
Teraz som si nahral incflex2 do s55 fw91 podla popisu na stranke a spostupom aky uvadza SPAKO na 4.strane diskusie v prispevku z 15.6.2004. Incflex som upravil podla postupu od JABLONCIK na 8. strane diskusie z 29.9.2004.
Funguje mi to, akurat sa obcas vyskytne nejaka chyba, budem to testovat a ozvem sa. Raz mi uz stihol zamrznut pri zvoneni prichodzieho hovoru, ale to mozno bola nahoda a trochu hapruje ukladanie sprav z niektorych priecinkov do archivu. Inac OK. Vypisuje vsak viac volneho miesta ako v skutocnosti ostava mam cca900k a pise mi 1.12M. |
Lasius kolemjdoucí
Zaslal: st leden 05, 2005 8:25 pm Předmět: |
Ozaj, vie mi niekto povedat, ci defragmentacia prebieha na spravnom mieste pamate? Zda sa mi ze nie, naviac je vzdy podozrivo rychlo urobena (cca3sek.!!) |
tacudek začátečník
Zaslal: pá leden 07, 2005 1:57 pm Předmět: |
Mám problem s Transfer T9 from 480000 to 3C0000.vkp je pro Fw 20 ale já mám 91 _________________ Bosh > Sagem > Alcatel 501 >S55 Fw 91+ 3x patch
www.tacudek.com :p
Lasius kolemjdoucí
Zaslal: pá leden 07, 2005 4:08 pm Předmět: |
tacudek napsal: | Mám problem s Transfer T9 from 480000 to 3C0000.vkp je pro Fw 20 ale já mám 91 |
Na fw91 mi to funguje perfektne podla popisu co som pisal vyssie, potrebne programy som stiahol na tejto stranke
(http://www.siemensmania.cz/content.php?id=119) a robil som to pomocou V-Klay v.3.
Podarilo sa mi to na prvy krat, ide to perfektne, akurat prec je hlasove ovladanie a niekedy ukazuje zle volne miesto v pamati. Inac absolutne ziadne problemy |
Lasius kolemjdoucí
Sko kolemjdoucí
Založen: 14. 02. 2005 Příspěvky: 1
Zaslal: pá únor 25, 2005 2:31 pm Předmět: problem s patchom incflex3 pre S55 FW91 |
Zdravim
Chcem sa opytat, ze ak pouzijem patch na S55 FW 91 na zvacsenie pamate na 1,7MB, ze ci hlasove vytacanie ma tam ostat, alebo nie?!
Lebo ked som pouzil ten pach, tak hlasove vytacanie bolo funkcne.
Na strankach vsade citamk ze o hlasve vytacanie pridem pri pouziti tohoto patchu!
Pamat mam 1.7 ale funguje mi aj to hlasove?! Kde som urobil chybu?
A mam podozrenie, ze ked nahram nejaky hlasovy zaznam, tak prepisuje cast firmware, lebo animacia pri odosielani SMS je posahana...
Som z toho jelen!
PS.: Po aplikovani tohoto 1,7 patchu na S55 FW 91, ci mozem pridavat dalsie pache?!
Dik za skoru odpoved |
Zaslal: so únor 26, 2005 9:32 pm Předmět: |
Hlasove vytacanie by nemalo fungovat.A patche nahravat mozes. _________________ Kdo umí, ten umí. Kdo neumí, ten čumí. |
vik kolemjdoucí
Založen: 18. 06. 2004 Příspěvky: 12 Bydliště: Bratislava
Zaslal: pá březen 18, 2005 7:33 pm Předmět: Nemecký Language |
Zdravím! Mám v S55 fw 20 language pack s jedným jazykom - anglickým, ale chcel by som nemecký. Neviete niekto kde by sa mohol nachádzať? Alebo ako si ho z kompletného language packu vybrať a uložiť ako nový languagepack? Vďaka za každú odpoveď! _________________ Alcatel OT DB --> Ericsson R320s --> Nokia 6210 --> Siemens C55 --> S55 --> CX75 |
