suawek kolemjdoucí
Založen: 12. 08. 2005 Příspěvky: 24 Bydliště: Stalowa Wola / Polska
Zaslal: čt březen 22, 2007 8:53 pm Předmět: |
Hello
I've a problem with SNES and vNES elf. I've put them in 0:\Zbin\emul directory in separate folders and added:
nes:0:\Zbin\emul\vNES\VNES.elf
smc:0:\Zbin\emul\SNES\SNES.elf
to extension.cfg located in the 0:\Zbin\etc directory (folder). Elf and folder names are correct, but when I try to open an nes/smc file, no matter that it's located on 0 or 4 drive, a "Can't run ELF" information is shown! What is wrong? Should rom files be in the Zbin directory (Zbin is invisible so I cannot get into it from my phone).
Thank you for answer.
Suawek |
