huteusz kolemjdoucí
Založen: 29. 08. 2007 Příspěvky: 13 Bydliště: Krakow-Polska
19.00 SMM
Zaslal: út březen 18, 2008 7:13 pm Předmět: |
Hello.
Is there any chance that this patch will be ported to Langpack91? It is really cool, but i don't know how to use e71gc in order to edit this patch
Thanks for any help. The only thing i has done is to change size of default fonts but... it's not that. |
Zeu5 kolemjdoucí
Založen: 30. 12. 2006 Příspěvky: 9 Bydliště: Russia, 64region
10.10 SMM
Zaslal: po srpen 25, 2008 7:45 am Předmět: |
if you have patch maked for lg03_El71_v41 and you need using it on lg91, put string "+578E0" to start of patch file
gl
+New version of this prog already done..
SGC can replace graphics in the our phones better!
Supported S-Gold and New S-Gold (all x65, x75 & ELKA models)
But prog can't work with fonts.. will added in next versions
If you want to help me in testing PreRelise version, use ICQ please
(my number 77222116) _________________ SiemensGraphicChanger Developer
screen |
