:: View topic - Vypinani telefonu
Vypinani telefonu
Pitisek
PostPosted: Thu Nov 17, 2005 3:33 pm    Post subject: Vypinani telefonu Reply with quote
Zdur bambusaci... mam mensi problemek, kdyz mam baterku pod 20% (kdyz ma vic nez 20% tak je vse OK) a pokusim se vlizt do prijatych nebo odeslanych zprav a nebo se pokusim vytvorit novou tak se mobil jednoduse vypne. Ale pokud si to nastavim na rychlou volbu, tak se tam dostanu. FM jsem prehravat zkousel, ale nepomohlo to. Mam S65 s oficialni 50kou
No*ia 3210 --> Siemens S65 FW12-->FW25-->FW43-->FW50
tomaslanger
PostPosted: Thu Nov 17, 2005 3:48 pm    Post subject: Reply with quote
a mas ho v zaruce?
C35i -> M35i -> A60 -> CSL65 -> S65
Pitisek
PostPosted: Thu Nov 17, 2005 3:53 pm    Post subject: Reply with quote
tomaslanger wrote:
a mas ho v zaruce?
To je prave ten zadrhel, uz neni v zaruce Sad jinak by uz sel do rukou nekomu povolanemu
tomaslanger
PostPosted: Thu Nov 17, 2005 3:55 pm    Post subject: Reply with quote
Aha, tak to teda netusim,co s tim...
lolec
PostPosted: Thu Nov 17, 2005 5:31 pm    Post subject: Reply with quote
hm mozno je to blba otazka ale aj taq: kolko mas tu baterku?? mozno ze je problem v nej.....
tom-as
Location: FIT VUT Brno CZ, občas Piešťany SK, ještě míň Tábor CZ
0.00 SMM
PostPosted: Thu Nov 17, 2005 5:45 pm    Post subject: Reply with quote
mozna by pomohlo nahrani cizi FF (mozna je neco spatnyho v EEPROM), ale potom ho nezapomen odblokovat
a na baterku bych to nevidel, kdyby to bylo baterkou tak se vypne normalne a ne ze zhasne display a je (a nedelalo by to jen u sprav)
ale este bych pockal na jiny nazory
( Siemens C35i -> S35i ) + Sony CM-DX1000 + Nokia 5110 + Siemens C35i + Siemens A55@C55@888kB +
Pitisek
PostPosted: Thu Nov 17, 2005 9:49 pm    Post subject: Reply with quote
No baterce je ani ne rok :/
Pitisek
PostPosted: Thu Nov 17, 2005 9:50 pm    Post subject: Reply with quote
oki, jeste teda pockam na dalsi nazory a kdyztak bych to zkusil a neni treba nejakej programek na opravu EEPROMky ?
