:: View topic - CX 65 nelze zapnout!
p+m
PostPosted: Fri Dec 30, 2005 8:31 pm    Post subject: CX 65 nelze zapnout! Reply with quote
Mam CX65 a nelze ho zapnout. Po stisknuti tlacitka ZAPNOUT displej jemne blikne( osvetleni NE) a pipne. Chtela jsem vytahnout sim a po zpetnem zasunuti ho uz nejde zapnout!Nenabiji, pres servisni kabel ho nelze detekovat ani prehrat firmware. Dvakrat se mi podarilo po dlouhem drzeni tlacitka telefon zapnout a pak se hned vypnul. Batrie dobra! MOOOOOOOOOOOC Vas prosim o pomoc predem dekuji! Pray
Maceman
Phone: 736735877
687.40 SMM
PostPosted: Fri Dec 30, 2005 8:40 pm    Post subject: Re: CX 65 nelze zapnout! Reply with quote
stalo se mi neco podobneho na siemensu C55 .jak se stalo ze prestal fungovat???
HTC Desire
SE P990i
Pajas
771.24 SMM
PostPosted: Fri Dec 30, 2005 9:04 pm    Post subject: Reply with quote
No a spoji se ti z necim V_klay,Freia?
p+m
PostPosted: Fri Dec 30, 2005 9:43 pm    Post subject: Reply with quote
Ne nespoji se vubec s nicim! Not talking
PostPosted: Fri Dec 30, 2005 10:44 pm    Post subject: Reply with quote
Oprava by bola moc zlozita a nie je iste,ci by sa podarila,ci to nie je aj HW.Ak mas telefon v zaruke,chod ho reklamovat,povedz,ze nejde zapnut.Po vytiahnuti a vlozeni SIM sa takato porucha nesmie stat.
whitewash
0.00 SMM
PostPosted: Fri Dec 30, 2005 10:50 pm    Post subject: Reply with quote
Suhlas... Taketo priznaky sa prejavuju napriklad pri poskodenej EEPROM alebo tak... Urcite nie po vytiahnuti SIM...
