:: View topic - x65 .... změna ikon menu
Goto page Previous  1, 2, 3 ... 17, 18, 19 ... 22, 23, 24  Next
Drobcek9056
7860.92 SMM
PostPosted: Mon Oct 10, 2005 5:56 pm    Post subject: Reply with quote
Chcem sa opytat, ci nema niekto skusenosti s vymenou ikoniek na x75, najlepsie na CF75. Som si odomkol skryte disky, ale mam tam iba ikonky Surf/zábava a ostatne tam niesu. Ako ich tam mam dat, ked ostatne tam niesu? Ale ked si prezeram tie subory s priponou *.fs, tak tam pise nieco o tych ikonach. Ci treba zmenit aj tie subory s *.fs?
momentalne SL55 Smile
PostPosted: Mon Oct 10, 2005 6:09 pm    Post subject: Reply with quote
to je v poriadku,ze tam nie su ikony...v original main.fs su odvolavky na ikony vo FW telefonu.Ak chces ine ikony,tak si iba stiahni,ktore chces a skopiruj si ich do Flex menu
dodko
PostPosted: Thu Oct 20, 2005 7:17 pm    Post subject: otazka Reply with quote
color#FF0000 Ahoj!Potrebujem poradit.Napojim mobil cez kabel,dam do it! Brick wall Brick wall Brick wall a nejde to pise chybu.Prosim pomozte.Dakujem vpred tym co odpisu Exclamation Exclamation Exclamation Pray Pray Pray
pecanz
14931.66 SMM
PostPosted: Thu Oct 20, 2005 7:20 pm    Post subject: Re: otazka Reply with quote
Nastavils to správně? Anebo to skus znovu... wink
EfineSS
PostPosted: Sat Nov 12, 2005 12:59 pm    Post subject: Reply with quote
Nahral jsem si do sveho CX65 ikonky a je kolem nich (2mm okraj) takove bile pozadi ktere je odlisne od pozadi menu... co s tim?
Philips Savvy -> Alcatel OT 302 -> Nokia 3210 -> Sony CMD-J6 -> Nokia 3510i -> Siemens CX65 (FW50) & Original Siemens DCA-510
hairy.pecker
PostPosted: Sat Nov 12, 2005 1:52 pm    Post subject: Reply with quote
Exclamation http://siemensmania.cz/forum/viewtopic.php?t=16714 Exclamation
hobit
taii
PostPosted: Thu Nov 17, 2005 7:33 pm    Post subject: Reply with quote
Nahral sem si do telefonu ikonky menu a pak mi neslo v menu jit do nastaveni a hlasilo to:"Could not load setup.fs. fs-file (/2:/japp/FlexMenu/setup.xml) was not found)" ale vzdycky to skoro hned zmizi Embarassed Crying or Very sad (skousel se 3 ruzny druhy ikonek)
A 50-> CT65-> CSLT65-FW53-DCA-510
Máme odpověď na všechny vaše otázky...
více na http://www.brambory.xf.cz ... wink
PostPosted: Thu Nov 17, 2005 7:37 pm    Post subject: Reply with quote
Vymazal si si potrebne *.fs subory. Tu ich najdes dohraj si ich tam.
Arrow http://siemensmania.cz/download.php?file=/other/ConfigCaS65_Siemensmania.zip
taii
PostPosted: Thu Nov 17, 2005 7:40 pm    Post subject: Reply with quote
Shocked , takz to sem teda nechtel smazat Exclamation
LeXus
PostPosted: Sat Nov 19, 2005 12:51 am    Post subject: Reply with quote
Nevím jak, ale povedlo se mi po nahrávání ikonek nadobro odkráglovat pravou horní ikonku "globusu" na pozici "3". Je nahrazena ikonkou "složky" a nemá žádnou funkčnost, čili nikam odkazem nevede, po najetí se zobrazí nahore jen číslo ikonky čili "3" ale žádnej popisek. Schrnuto je mrtvá. d'oh! Nahrátím jiných ikonek se nic nezpraví, furt tam ta konkrétní složka je se stejným vzhledem a nulovou funkčností... Nevíte někdo co s tím? Popřípadě nemohli by jste mi na mail [email protected] poslat zalohu "originálních" ikonek? Embarassed
Siemens S35i => ST60 => CX65 (FW 50cz, DCA-510)
pecanz
14931.66 SMM
PostPosted: Sat Nov 19, 2005 8:24 am    Post subject: Reply with quote
No počkej a nahráváš tam i soubor main.fs??? Anebo neměl jsi tam reklámní software? A původní ikonky máš TADY
PostPosted: Sat Nov 19, 2005 9:00 am    Post subject: Reply with quote
Zmaz z telefonu cely adresar Config/japp/FlexMenu a nahraj si tam adresar FlexMenu z tohoto Configu:
Arrow http://www.siemensmania.cz/download.php?file=/software/ConfigX65_Siemensmania.zip
...a ked sa chces rypat v ikonach,najprv si poriadne precitaj navody.Staci totiz zmazanie niektorych fs suborov,alebo spatny main.fs a menu je nefunkcne,ako je to u Teba.
LeXus
PostPosted: Sat Nov 19, 2005 3:17 pm    Post subject: Reply with quote
Díky, díky, díky...! Co bych si bez Vás hoši počnul, jste fakt borci...
martin_o
PostPosted: Fri Nov 25, 2005 3:27 pm    Post subject: Bluetooth Reply with quote
Zajímalo by mne jestli lze použít na změnu ikon nejen kabel ale i Bluetooth (zobrazit Fullflash)
Drobcek9056
7860.92 SMM
PostPosted: Fri Nov 25, 2005 3:38 pm    Post subject: Re: Bluetooth Reply with quote
No neviem ako si to myslel, a preco chces zobrazit FF? Tak to neviem na co ti je. Mal si asi na mysli skryte diksy. Tak pokial si ich odkryjes bud cez ODD Tools, alebo pouzitim pluginu v Total Commaderi, tak by ti to malo ist. Len s BT som este nerobil,tak ani neviem,ci ho najde ako COM port,alebo na principe IrDA (sice to asi tiez najde ako COM port).
Nied nad stary dobry kabel .
Page 18 of 24
