:: View topic - Kterou paměťovou kartu?
Goto page Previous  1, 2, 3, 4  Next
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Řada x72, x75
matus201
PostPosted: Tue Dec 13, 2005 8:23 pm    Post subject: Reply with quote
Viem ze DV ide (zevraj) ale ide aj na Kingston? A ktoru kartu by ste mi poradili z tejto stranky?
http://www.alzasoft.sk/Default.asp?CatID=18843885&TYPTREE=1
beardie
7865.50 SMM
PostPosted: Tue Dec 13, 2005 8:28 pm    Post subject: Reply with quote
ja mam vyhliadnutu tuto,zajtra ju idem otestovat
edit:ma dost brutal cenu,ja som ju videl za 766 s dph!!!
pkas
PostPosted: Tue Dec 13, 2005 8:32 pm    Post subject: Reply with quote
Ale ved v telefone ti netreba velku rychlost - ked pustas 5MB mp3 tak ti nacita prvych par sekund, hned otvori a potom pocas prehravania postupne nacitava dalsie casti. Pri obrazkoch je to o inom, ale tie nezaberaju viac ako 1MB.[/quote]
Jasna paka.
Nevim tedy, zda se vubec v praxi pri pouzivani v telefonu projevi nejaky zasadni rozdil... Question (krome rychlejisho zapisu/cteni) pomoci ctecky karet (a udajne nizsi spotreby) ale ne vzdy znamena nizsi napeti = nizsi spotreba...
Philips FIZZ -> Nokia xxxx -> Motoshitorola d520 -> C25 -> C35i -> ME45(fw28)....forever -> M75(fw13) + DCA 510 + RS-MMC 512 SanDisk (dead) -> M65(fw50)
Romenek
PostPosted: Tue Dec 13, 2005 11:33 pm    Post subject: Re: Kterou paměťovou kartu? Reply with quote
Rozhodne neberte KINGSTON RS 512 MB, mne v CX75 zlobila a musel jsem ji vratit, vetsinou se tvarila OK, ale nekdy neslo zapisovat a nebo cist soubor, za chvili to pak zase slo.
gorgeous007
PostPosted: Wed Dec 14, 2005 2:16 pm    Post subject: Re: Kterou paměťovou kartu? Reply with quote
Mne robi presne to iste moja PQI RS-MMC 256MB. Smile
duro
PostPosted: Wed Dec 14, 2005 2:20 pm    Post subject: Blbnuca karta Reply with quote
No ja mam v CX75 RS MMC DV 256Mb PQI a ide uplne bez problemu, takze to bude asi tvojim telefonom. Alebo ju este skus formatovat v pc cez citacku kariet a potom v telefone. Malo by to pomoct. Ja ale ziadne take problemy nemam, mne ide bezvadne od zaciatku.
abaddon
270.00 SMM
PostPosted: Wed Dec 14, 2005 2:58 pm    Post subject: Reply with quote
jen se zeptám,ohledně těch pam.karet.když vyndám úplně novou kartu hned z obalu do telefonu,i kdyý na ni nic neni,je nezformátovaná,řekne mi ten tel.že tam je?bo jí musim zformátovat(jestli jo taj jak v telefonu).dnes si pro ni jdu do jakého si obchodu kde sem si ji objednal a hned ji chci vyzkoušet,tak ať tam nešaškuju. Crying or Very sad thanx
romboid
PostPosted: Tue Dec 20, 2005 11:46 pm    Post subject: Reply with quote
a co karta A-DATA Multimedia Card 256MB RS 1.8V? (http://www.agem.sk/?cmd=tovar_detail&product=6615777) myslite ze bude dobre fungovat v CX75?
nokia 8110, motorola T192, A55->C55, CX75fw25 + Apacer uz len 256MB + ELF + patches + kabel Siemens DCA-510
gorgeous007
PostPosted: Wed Dec 21, 2005 3:33 pm    Post subject: Reply with quote
Ak ju tam das ked bude telefon zapnuty, bude sa tvarit, ze tam nie je. Ale ked ho vypnes a znovu zapnes, pri zapinani napise "Karta chybna alebo nie je naformatovana". Potom ju naformatujes a mas ju v pohotovosti.
gorgeous007
PostPosted: Wed Dec 21, 2005 3:34 pm    Post subject: Re: Blbnuca karta Reply with quote
Tak este to vyskusam, aj ked som to uz raz robil.
gabos
PostPosted: Thu Dec 22, 2005 11:34 pm    Post subject: SanDisk Reply with quote
Ja som to za 937 SK vyriesil este pri SX1 256MB RS-MMC SanDisk... Teda vtedy sa otec pomylil a kupil rs namiesto klasickej. Teraz to vyhovoju Very Happy ... Ide uplne nema problema, telefon ju berie, aj citacka (UNBELIEVABLE ale za 249 SK z LIDL-u, SilverCrest cita 16 formatov !!!) takze SanDisk-u plne doverujem
Ericsson T28s (dedictvo po dedovi) -> Siemens A50 -> Siemens SX1 , 256 MB RS-MMC -> Siemens CX75, 256 RS - MMC, headset -> SE W710i komplet... Wink -> Nokia 6120 classic
sors
PostPosted: Sun Dec 25, 2005 10:37 pm    Post subject: Reply with quote
mam Transcend 512MB a funguje ok...
BOSCH Com 608 -> PANASONIC GD 93 -> SE R 600 -> ALCATEL OT 535 -> SIEMENS CX75 + RS-MMC Transcend 512MB
romboid
PostPosted: Mon Dec 26, 2005 7:53 pm    Post subject: Reply with quote
tak som kupil apacer 256mb mobile dual voltage a zatial je uplne fpohodicke
http://www.agem.sk/?cmd=tovar_detail&product=6863877
kesu
14913.56 SMM
PostPosted: Tue Dec 27, 2005 12:27 am    Post subject: Reply with quote
JJ tuhle akorát že 512MB jsem si včera objednal,tak uvidíme.
Chtěl jsem se zeptat jaký je rozdíl mezi normální a DV ?
firewalker
PostPosted: Tue Dec 27, 2005 12:55 pm    Post subject: Reply with quote
objednal jsem si dneska prave kingstone 256MB DV RS-MMC
http://www.okcomputers.cz/DetailPage.asp?DPG=54009
tak sem zvedavej, jestli to pojede nebo ne Sad mam FW05 v CX75, tak fakt se necham prekvapit... ale snad to pude Smile)
btw. myslite si, ze kdyz nekomu nefunguje DV a druhemu ano, je to HW nebo SW chyba?
ME45 FW28 -> ME45 FW30 -> ME45i FW04 -> own tuning -> CX75 FW05
..::Firewalker::..
This topic is locked: you cannot edit posts or make replies.     Forum Index -> Řada x72, x75 All times are GMT + 1 Hour
Page 2 of 4
