:: View topic - Diskusia k funkcnosti patchov x65,CX70
Goto page Previous  1, 2, 3 ... 35, 36, 37 ... 43, 44, 45  Next
robinho
PostPosted: Tue Jan 03, 2006 6:00 pm    Post subject: Reply with quote
Stranger:
are you sure its not working?? wrote some text "I invite you to my party. Will you come?" then go right button to OPTIONS and select DELETE TEXT you should receive "IInviteYouToMyParty.WillYouCome?"
unfortunatly i have only s65v58 so cant test it but i use similar patch in sl45i.
best regards
robinho from poland:)
edit:
uhh sorry all, i see Lasky tested that patch also and didnt work so i`m stupid:/
PostPosted: Tue Jan 03, 2006 6:08 pm    Post subject: Reply with quote
robinho wrote:
Stranger:
best regards
I think you are talking about some else. What DELETE TEXT. IN patch description isn´t anything like that.
robinho
PostPosted: Tue Jan 03, 2006 6:11 pm    Post subject: Reply with quote
"0A6D868: 87F0D2EE 70F254FC ; options -> clear text"
its predefined options to recall compressing sms, please try it (Cestina should be "Smazat text"
PostPosted: Tue Jan 03, 2006 6:17 pm    Post subject: Reply with quote
It´s a big difference between these two patches. Hand I think SL45 and x65.
robinho
PostPosted: Tue Jan 03, 2006 6:30 pm    Post subject: Reply with quote
hmm what differenece do you see?
x65 "automatically removes all blanks from message content and converts following character to upcase if necessery"
x45 "The text is replaced in that kind:
becomes to "IInviteYouToMyParty.WillYouCome?"
So all spaces will be removed."
different code but same results. to pity my brother sold cx65 because i`m almost sure my opinion :/
please dont be angry
PostPosted: Tue Jan 03, 2006 6:53 pm    Post subject: Reply with quote
Hups, I tought that you are allways talking about security patch. Embarassed Laughing
IMHO compression patch isn´t buil for our language, ´cause it can´t be applied. Writes an error. Rolling Eyes
Mayki
PostPosted: Wed Jan 04, 2006 9:13 pm    Post subject: Reply with quote
Nějak nemůžu dostat do telefonu patch 665 Black alebo White list v. 1.3 pro FW50CX65,na FW43 mi šel v pohodě.
Vždycky jsem si myslel,že se to týká jen grafických patchů,dá se to nějak spravit?
PostPosted: Thu Jan 05, 2006 11:12 am    Post subject: Reply with quote
Musi sa Ti bit s inym systemovym patchom.Ja ho v telefone mam a funguje bez problemov.
Mayki
PostPosted: Thu Jan 05, 2006 11:45 am    Post subject: Reply with quote
Jak se dají upravit systémové patche aby spolu nekolidovaly? U grafických to umím, ale u systémových... Question
PostPosted: Tue Jan 10, 2006 8:01 pm    Post subject: Reply with quote
Ano,ide...ale nie u vsetkych patchov a je to velmi komplikovane.
Stranger
276.00 SMM
PostPosted: Sun Jan 22, 2006 9:54 am    Post subject: Reply with quote
prehravam si prave firmware na telefone a tak som ten patch na skracovanie sms nahral. a cuduj sa svete, vsetko funguje. skusal som aj sms s diakritikou a ta bola skratena taktiez korektne. budem este testovat ale zatial to vyzera fajn. a ps: polozka skracujuca sms ma nazov "Zoom -" Smile.
PostPosted: Sun Jan 22, 2006 10:17 am    Post subject: Reply with quote
Síce sa mi ho už podarilo aplikovať (takmer čistý mobil) aj sa mi v menu sms objavila položka tranz, ale nereaguje. Nič sa s textom nestane.
Skúsil som aj odobrať tech font čo tam mám, ale bezvýsledne.
kwash
303.22 SMM
PostPosted: Sun Jan 22, 2006 3:36 pm    Post subject: Reply with quote
Think je normalne ked mam patch mini gps a naladi mi novu bts a neprepisem ju k obrazu svojmu pri nasledovnom preladeni vypne telefon a to mam standardne pred cell12345 nulu-do nothing
a este mi na tom patchi nieco ine salie ked si dam napr.rezim 1 tak pri urcitom preladeni vyhodi kriziky a telefon je bez signalu aj na miestax kde signal stopercentne je
je to dost mozne ze koliduje s neakym inzm patchom tak ak mate skusenosti s niecim podobnym tak mi natrite toho parxanta az ho sejmem
CX70fw56+switxing cable DCA-510<->DCA-500,S75 black,N95 8gb
Stranger
276.00 SMM
PostPosted: Tue Jan 24, 2006 12:33 pm    Post subject: Reply with quote
no tak uz je dotestovane. vsetko ohladne toho skracovania sms funguje ako ma a zda sa ze nema nijake vedlajsie ucinky (par bugov sa najde no rychlo sa daju pochopit a pouzit). telefon mam naozaj dost napatchovany a tento som nahraval ako posledny. isiel bez problemov (neziadal ani REPAIR). ak este bude treba este nejake info poskytnem ale mohli by ste sa s robinhom dohodnut a zaradit ho na vase stranky.
bobas
PostPosted: Mon Jan 30, 2006 7:26 pm    Post subject: Reply with quote
Odkaz patche 271 Stále zaplé podsvícení ve zvoleného profilu - verze 2.2 pro SL65 fw50 smeruje na * Keypadlight Trigger v2.2 *. Protoze patch Stále zaplé podsvícení ve zvoleného profilu pro SL65 neexistuje (i kdyz by hafo bodnul), ma seten patch jmenovat asi treba Nastaveni podsvetleni klavesnice podle profilu.
Počítač bez Windows je jako kakao bez kečupu.
Oskar (stálý zákazník = 1577Kč) - C65 fw12 -> fw25 + patche -> fw43 + patche -> fw48 + patche -> fw50 + patche + IncFlex ->CSL65
Page 36 of 45
