:: View topic - sx1 a MMC overclocking patch
Goto page 1, 2, 3 ... 10, 11, 12  Next
duuri
5874.50 SMM
PostPosted: Tue Jan 10, 2006 7:10 pm    Post subject: sx1 a MMC overclocking patch Reply with quote
davajte pozor najprv si ho prestudujte:)
Patch No. 51
; SX1 overclock patch v1.0
; v1.0
; changes bootcore of Z1 firmware image
; by Vovan888 ([email protected]) 08.01.2006
; oslik.ru
; dedicated to Z-team and overclockers.ru
; !!! DANGER !!! CPU can overheat and overburn !
;168 Mghz
replace:303A00000010FEFF00102000FFFFFEFFEFFFFFD1:303E
; multipliers table: (cpu_freq = 12 * mult / 2)
; mult
;11 10100 01 10000
;01101 = 13 = 78M = 11011010110000=36B0
;10100 = 20 = 120M = 11101000110000=3A30
;11001 = 25 = 150M = 11110010110000=3CB0
;11100 = 28 = 168M = 11111000110000=3E30
;11101 = 29 = 174M = 11111010110000=3EB0
Patch No. 52
; Increase MMC Speed (test) v0.1
; Sets MMC freq to 24 Mghz
; by Vovan888 ( vovan(at)oslik.ru ) 08.01.2006
; Ekern_exe_421
;50005E08
replace:030052E30900000A020000CA000052E3:02
;50005E40
replace:0320A0E3DC8E00EA0C68005808009FE5:02
; epbusm.dll
;5002F11C - change ADDNE R3, R4, #1
replace:013084120338A0112348A0110C00A0E3FF10A0E3:013044020338A0012348A001
fROM
http://forum.oslik.ru/viewtopic.php?t=7933&start=45
Code:
results in SPMark04_v110_free_S60
120mghz
score=492
8.28 fps
1.93Mtexels/s
24.27 Ktriangles/s
150mghz
score=615
10.38 fps
2.40Mtexels/s
30.41 Ktriangles/s
168mghz
score=695
11.68 fps
2.73Mtexels/s
34.16 Ktriangles/s
KŘOVÁK
PostPosted: Tue Jan 10, 2006 7:38 pm    Post subject: Reply with quote
mohl by si prosim te trosku vysvetlit k cemu ze to je? Embarassed
"I myšlení občas škodí zdraví."
(\__/)
(O.o )
(> < ) THIS IS BUNNY!
duuri
5874.50 SMM
PostPosted: Tue Jan 10, 2006 7:45 pm    Post subject: Reply with quote
prvy patch pretaktuje procesor na 168 MHZ a druhy citacku MMC na 24 MHZ
Norton
1272.54 SMM
PostPosted: Tue Jan 10, 2006 8:36 pm    Post subject: Reply with quote
Už jsem na to koukal na SFku a jak budu mít chvilku čas,tak to zkusím.Někdy opravdu žasnu co všechno s těma našima "miláčkama" jde udělat. Shocked Za tohle prostě Siemensy miluju.
C35i -> MT50 -> CX65 -> SX1 -> Nokia N70
jaramara
PostPosted: Tue Jan 10, 2006 9:34 pm    Post subject: Reply with quote
Jede to a jde to hodně poznat na rychlosti, fakt super! Ale když jsem do svýho packu přidal i ten na MMC, tak se žádný OC nekonalo, ale pak to ještě zkusím předělat!
Siemens SX15en(czT9)/ja_ma mod 36patches core 168Mhz !!DEATH!! =); Trancend512MB; joy 6600 and Samsung X200 (vodafone)
NOW_NOKIA_ /\/70 _ rulezz =)
duuri
5874.50 SMM
PostPosted: Tue Jan 10, 2006 9:37 pm    Post subject: Reply with quote
ako myslis kartu to nepretaktovalo?
jaramara
PostPosted: Tue Jan 10, 2006 9:39 pm    Post subject: Reply with quote
No to nevím a ani nevím jak bych to mohl pozorovat, ptž když jsem tam přidal obadva, tak se žádný OC nekonalo, tak jsem ten patch na MMC vyhodil a v pohodě, ale zkusím to ještě nějak upravit, celý ten pack.
Ty jsi to už zkoušel?
duuri
5874.50 SMM
PostPosted: Tue Jan 10, 2006 9:46 pm    Post subject: Reply with quote
dal som tam obidva ale ja som podtaktoval na 78 a menu ide pomalsie...takze u mna to snad ide len ako testnut kartu snad nejakym softom na test kariet pod symbianom
jaramara
PostPosted: Tue Jan 10, 2006 9:49 pm    Post subject: Reply with quote
Jn, takový žádný neznám Think Ale nějak jsem vůbec nepochopil k čemu to může být dobrý d'oh!
Nemůže se tím MMC poškodit?
duuri
5874.50 SMM
PostPosted: Tue Jan 10, 2006 9:50 pm    Post subject: Reply with quote
ono povedne to bolo od siemensu ale potom to znizili v novsom firmware kvoly kompatibilite...ale malo by byt rychlejsie citanie a zapisovanie na kartu
jaramara
PostPosted: Tue Jan 10, 2006 9:57 pm    Post subject: Reply with quote
Tzn. že by se i mohl zrychlit třeba MsVDriveE?
duuri
5874.50 SMM
PostPosted: Tue Jan 10, 2006 10:25 pm    Post subject: Reply with quote
no teoreticky hej ale ved msvdrive pustis len raz...skor by som povedal ukladanie videa alebo tak
paja_m55
PostPosted: Wed Jan 11, 2006 8:14 am    Post subject: Reply with quote
msdrivee ti jenom presmeruje ukladani na kartu takze ten zapis sms/mms by mel byt pak rychlejsi,no vyzkousim,snad phone neusmazim jako cpu v pocitaci Smile a jeste jedna vec? jakej to ma vliv na baterku? vydrz musi jit rapidne dolu,co? Sad
2x C35i -> OT501 -> SGH-C100 -> M55 -> SX1 -> S65 -> Nokia E50 -> Nokia E51 -> T-Mobile MDA Compact IV
--== AMD 4evr ==--
Gwin
0.84 SMM
PostPosted: Wed Jan 11, 2006 11:22 am    Post subject: Reply with quote
Pokud ty patche funguji, bude to parada. Co nejdriv vyzkousim.
jaramara
PostPosted: Wed Jan 11, 2006 1:06 pm    Post subject: Reply with quote
Takže od rána pořád něco dělám, mám OC na 144MHz a úplně v pohodě , myslím že to moc víč žrát nebude Dancing Applause wink
Page 1 of 12
