:: View topic - CX70 V_klay jak nahrat patch pres v_klay
Moucha
60.08 SMM
PostPosted: Mon Apr 03, 2006 7:25 pm    Post subject: CX70 V_klay jak nahrat patch pres v_klay Reply with quote
Nevíte jak nahrát nejakej patch pres V_klay kdyz tam cx70 neni nebo neznate nejakej jinej program na nahrati patchu
Stranger
276.00 SMM
PostPosted: Mon Apr 03, 2006 7:32 pm    Post subject: Reply with quote
postup je rovnaky ako pre radu x65. vygenuruj si kody, zapis S-key a ten standarny loader pre password loading si uprav. vkopiruj tam cislo vygenerovane cez papua utils a mozes zacat vesele pouzivat V-klay s tvojim founom a loaderom pre x65 Smile.
Moucha
60.08 SMM
PostPosted: Mon Apr 03, 2006 7:41 pm    Post subject: Reply with quote
No to je hezky ale ja to tak docela nechapu spis mi vsecho poradne vysvetli
Moucha
60.08 SMM
PostPosted: Mon Apr 03, 2006 7:43 pm    Post subject: Reply with quote
jaky kody kam to mam presne napsat a pres co nebo kde to mam stahnout?
Stranger
276.00 SMM
PostPosted: Mon Apr 03, 2006 7:47 pm    Post subject: Reply with quote
no cely postup je trochu zdlhavy. ak si ale precitas toto: http://www.siemensmania.cz/forum/viewtopic.php?t=6660, ak si to naozaj pozorne precitas tak to mas vyhrate. naozaj ti nedokazem vysvetlit celu problematiku vystiznejsie ako je to tu. mozem ti len drzat palce.
Moucha
60.08 SMM
PostPosted: Mon Apr 03, 2006 7:49 pm    Post subject: Reply with quote
no zkusim to
