:: View topic - predelavka A57 na A70
Goto page 1, 2  Next
Reply to topic     Forum Index -> x62 a starší řady -> x50
Moucha
60.08 SMM
PostPosted: Tue May 30, 2006 4:22 pm    Post subject: predelavka A57 na A70 Reply with quote
Nevim kam sem to mel dat zadna sekci tady na to neni tak sem to hodil sem,
Chtel bych se zeptat jestli by sla predelat A57 na A70 a kdyz jo tak jak?
PostPosted: Tue May 30, 2006 4:42 pm    Post subject: Reply with quote
Nie,ide prerobit iba na C55 po prerezani testpointu.
Moucha
60.08 SMM
PostPosted: Tue May 30, 2006 4:48 pm    Post subject: Reply with quote
A je na to nekde navod?
PostPosted: Tue May 30, 2006 5:03 pm    Post subject: Reply with quote
Arrow http://www.siemensmania.cz/content.php?id=144
Testpoint je v sekcii Testpointy.
Moucha
60.08 SMM
PostPosted: Tue May 30, 2006 5:10 pm    Post subject: Reply with quote
No jo ale tohle je A57 a ne A55
PostPosted: Tue May 30, 2006 6:02 pm    Post subject: Reply with quote
to nevadi,su rovnake.Len musis urobit testpoint
Moucha
60.08 SMM
PostPosted: Tue May 30, 2006 6:11 pm    Post subject: Reply with quote
No abych to nepodelal ja to chci delat kamosce chapes tak to musi pak normalne fakat takovyhle zasahy na desce nemam rad, no zkusim to a jak mam udelat ten testpoint to mam vzit nejakej nozik a uriznout to?
Bond
14861.00 SMM
PostPosted: Tue May 30, 2006 6:13 pm    Post subject: Reply with quote
jo musíš to tam řezat tak dlouho než uslyšíš takový lupnutí tím se to přeřízlo
Moucha
60.08 SMM
PostPosted: Tue May 30, 2006 6:17 pm    Post subject: Reply with quote
OK tak ja to zkusim pak napisu jak to dopadlo, nezarucuju ze to bude v nejblizsi dobe musi si to jeste rozmyslet to vite trochu mi neveri
PS: Kde sou napsany ty hodnosti jak to de za sebou myslim jako ja mam zacatecnik tak kdy preskocim na dalsi uroven?
PostPosted: Tue May 30, 2006 6:20 pm    Post subject: Reply with quote
To si dufam nemyslel vazne wink ziadne lupnutie pocut nie je.
Bond
14861.00 SMM
PostPosted: Tue May 30, 2006 6:21 pm    Post subject: Reply with quote
no tak lupnutí přímo ne ale jako takovej divnej pocit. no jednoduše až to řízneš tak to poznáš
132978.34 SMM
PostPosted: Tue May 30, 2006 6:26 pm    Post subject: Reply with quote
lupnutí?? to by přeřezal celou zákl. desku, ne?
Rezal som nedavno na A55 a C60...to miesto,kde sa to reze je velmi miniaturne a naozaj tam nic nelupne..proste musis davat pozor,aby si nezarezal moc hlboko.
Bond
14861.00 SMM
PostPosted: Tue May 30, 2006 6:30 pm    Post subject: Reply with quote
já ho právě přeřezal asi po půl hodině protože sem nevědel jak na to ale to lupnul jen ten kablík (teda jestli sem řezal dobře, ale mobil funguje )
Moucha
60.08 SMM
PostPosted: Tue May 30, 2006 8:24 pm    Post subject: Reply with quote
Jo a vubec vyplati se to udelat z A57 na C55 protoze A57 je novejsi ze jo abych to nedelal zbytecne
Reply to topic     Forum Index -> x62 a starší řady -> x50 All times are GMT + 1 Hour
Goto page 1, 2  Next
Page 1 of 2
