:: View topic - Winswup C60
Winswup C60
Lukike
PostPosted: Fri Aug 25, 2006 7:33 am    Post subject: Winswup C60 Reply with quote
Mam taky problem ,... z nicoho nic mi vypla C60 a nejde zapnut proste pipne vypne,.... bezna vec....
Stiahol som FW27 winswup,nastavim port,rychlost,zaskrtnem prvy skip,dam start kratko stlacim cerv.tlacitko vsetko ide OK, new mobile SW je na 100% a potom mi nabehne cervena obrazovka Could not Ping Mobile ako ze nieje spojenie z telefonom,...
Preco mi to nabehne,ked najpv telefon najde a potom uz nie????Moze to byt baterkou???Neviem v akom stave nabitia je,...ked ju dam po siet tak iba pipne a a ani neukazuje stav nabijania hm
Co poradite ako dalej??? thx
AMD SEMPRON 3000+,, 256MB DDRAM,HDD 80GB/8MB,, DVDRW,..
Siemens SL65,FW50
Mrtva CX65 Sad(((
Lukike
PostPosted: Fri Aug 25, 2006 7:34 am    Post subject: Reply with quote
Este som to skusal na rychlostiach 57600 a 28800,... tiez to iste nabehlo po skonceny nahravania FW,...
Siemens SL65,FW50
Mrtva CX65 Sad(((
Lukike
PostPosted: Fri Aug 25, 2006 12:03 pm    Post subject: re Reply with quote
Som nahral aj FF cez V-klay a to iste robi hm Zapnem pipne a vypne,....je este sanca na ozivenie telefonu???
Siemens SL65,FW50
Mrtva CX65 Sad(((
PostPosted: Fri Aug 25, 2006 1:57 pm    Post subject: Reply with quote
Urcite je velka sanca na ozivenie tohoto telefonu, pocitaj vo forach a v clankoch. Ja osobne by som urobil este custonm s vymazanim... Ale to je iny pribeh...
Lukike
PostPosted: Fri Aug 25, 2006 3:01 pm    Post subject: re Reply with quote
Teraz mam dalsi problem,....stale ked nahravam FF tak cca 10min pred koncom mi nabehne toto
Siemens SL65,FW50
Mrtva CX65 Sad(((
Moucha
60.08 SMM
PostPosted: Fri Aug 25, 2006 3:06 pm    Post subject: Reply with quote
A mas zasrktnuty oba skipy?
wmmania.cz
Podpořte SiemensManii
Koukněte co zrovna poslouchám
D4X
(o(^^)o)
Phone: HTC Diamond
382387.67 SMM
PostPosted: Fri Aug 25, 2006 3:19 pm    Post subject: Reply with quote
2Moucha: FF se nahrava pres V_klay... zadne skipy tam nikdy nebyly wink
2Lukike: nemas moc vytizene PC? ja kdyz nahravam FF a pri tom delam jeste hafo dalsich veci tak mi to taky vetsinou pise tenhle error...
-> Nokia Lumia 800
Moucha
60.08 SMM
PostPosted: Fri Aug 25, 2006 3:32 pm    Post subject: Reply with quote
Aha sry Embarassed tohle si porad pletu
wmmania.cz
Lukike
PostPosted: Fri Aug 25, 2006 4:32 pm    Post subject: re Reply with quote
No okrem toho ma zapnuty net a ICQ,....
Siemens SL65,FW50
Mrtva CX65 Sad(((
doglik
PostPosted: Fri Aug 25, 2006 4:51 pm    Post subject: Reply with quote
Jo, měl jsem jednou taky takovej problém a nevědělo se, co s tím. Tak se phone dal do servisu a řekli, že je vadná deska... Jinak se mi to nepovedlo ničím dát dohromady,ale to ješte nebyl Joker (nebo jsem ho spíš neměl) Very Happy Zkus si tam nahrát FF přes něj a uvidíš. Když ti tel. nepojede normálně, ale alespoň ho zapneš, tak to alespoň spojíš normálně s V-Klayem a dáš si tam svoji zálohu (doufám, že ji máš)...
C35 (death) -> M55 fw10 -> M55 fw 91+mnoho patchů Smile -> S75 (tovární fw 35 Sad ) -> Update SW 47 - original Siemens
Lukike
PostPosted: Fri Aug 25, 2006 4:58 pm    Post subject: Reply with quote
Teraz som skusal zase FF cez V-klay a nic zase ta ista chyba apritom som nic z PC nerobil hm hm
Idem skusit Jokera
Siemens SL65,FW50
Mrtva CX65 Sad(((
