Doxxik všeználek
4285.00 SMM
Posted: Wed Oct 25, 2006 8:26 pm Post subject: |
EidzEm wrote: | hanni wrote: | U CX70v56 mi screenshoter 2 vypina fon..ale asi je to tym,ze mam MP 3.1 a nie MP14 |
Nie nie je. Mne to ide. |
Zaujimave...ked som nahral ten patch,telefon sa mi vypol asi 3x za 2 minuty..s niecim sa mi to asi bije a je to nestabilne. _________________ Kdo umí, ten umí. Kdo neumí, ten čumí. |
PRE[)ATOR kolemjdoucí
Posted: Thu Oct 26, 2006 7:03 am Post subject: |
EidzEm wrote: | No skontroluj si mas vytvorenu zlozku 0:\Misc\Shots ? |
jj mam az taky LoL som neni  |
Posted: Thu Oct 26, 2006 7:14 am Post subject: |
Lasky wrote: | 2 PRE[)ATOR:
Zrejme ti chyba funkcia v kniznici. Aplikuj toto:
Code: | +0FD4000
#pragma enable old_equal_ff
380: 0xA869E320 ; f224: RamScreenBuffer
+0 |
ee to nejde pise mi ze je uz aplikovany, to som aplikoval uz priamo v tom patchi screenshoter v2
mam tieto patche aplikovane:
clear_80.vkp
Disable_Card_defect__not__formatt.vkp
Disable_More_Nasty_Debug.vkp
ei71+techdigiclock_out.vkp
Change_progressbar_color_v1.vkp
pomale_zap_osv.vkp
RemoveIconWhiteBackgr__in_Nat_Menu.vkp
S65v58_library_16.9.2006.vkp
S65FW58_max_kompresia_JPEG.vkp
S65FW58_discs_selection.vkp
S65FW58_odstr_zvuku_pri_najdeni_siete.vkp
S65FW58_odstr_zvuku_pri_vytacani.vkp
S65FW58_open_discs.vkp
S65FW58_osv_po_5perc.vkp
S65FW58_pomale_skrolovanie.vkp
S65FW58_servisne_menu.vkp
S65FW58_zmena_nazvu_diskov.vkp
S65FW58_zmena_font_mainscreen_v2.vkp
S65FW58_zmena_progressbaru.vkp
S65FW58_zrychlenie_javy.vkp
S65v58_api_v8.1.vkp
S65v58_Blinker_CZ.vkp
S65v58_Disable_ASP.vkp
S65v58_disable_auma_dial_degug.vkp
S65v58_Disable_MMS_Debug.vkp
S65v58_extrainfo_v4.vkp
S65v58_Goto_menu_anywhere.vkp
S65v58_graph_patch_manager_v3.1av.vkp
S65v58_HF_bez_potvrdenia.vkp
S65v58_ico_nab_na_mainscreen.vkp
S65v58_master_patch_v5.vkp
S65v58_masterpatch_shutdown_crash_fix_v2.vkp
S65v58_megaloudness.vkp
S65v58_MMC_Sounds_v2.vkp
S65v58_mmi_logging-zrychlenie fonu.vkp
S65v58_neomedzene_nahr_videa.vkp
S65v58_odstr_hlasky_aktiv_profilu.vkp
S65v58_praca_s_telefonom_bez_SIM.vkp
S65v58_s_camera.vkp
S65v58_save_lists.vkp
S65v58_ScreenShoterv2.vkp
S65v58_superfast_menu.vkp
S65v58_techfont_do_extrainfov4.vkp
S65v58_vypnutie_debug.vkp
S65v58_zmena_zvuku_pri_prazdnej baterii.vkp
S65v58_zvuk_pri_ukonc_prenosu_dat.vkp
techfont_s65_FW58_diakritika.vkp
zrychlenie_klavmoje.vkp
Neviem ci sa to zide ale ak mi nieco chyba alebo vadi s tym ScreenShoterom...
cim robim screeny? Stup_Babysiter? prosim poradte Dakujem aj za tieto rady, skoda len ze to nejde... |
Posted: Thu Oct 26, 2006 7:20 am Post subject: |
este nieco ma napadlo...
Nemoze to byt ze v tom patchi Function Library co mam aplikovany je pod cislom 380 GPRS Trafic? a v tom ScreenShoteri je na 380 ten RamScreenShoter? asi nie co... ja neviem robit patche tak sorry  |
krMeEjNzy věrný diskusník
 Joined: 06 Nov 2005 Posts: 401 Location: javamania :o)
Posted: Thu Oct 26, 2006 8:15 am Post subject: |
Doxxik wrote: | mas CX70 ? (sem myslel, ze mas Csl65 ...) to by řešil elf od SH@dyho..... |
ee mam CX65@70... A zrovna tenhle patch by se mi tak hodil  |
Posted: Thu Oct 26, 2006 9:14 pm Post subject: JE TO SKORO OK |
Uz mi teda funguje screenshoter ale nejde mi robit screeny lebo ked dam na tlacitko internetove aby som odtial robil screeny tak ma vyhodi do mainscreen a tam urobi fotku a to zo vsade ako to ze vam to najprv ofoti a potom vyhodi? |
D4X (o(^^)o)
Posted: Thu Oct 26, 2006 9:31 pm Post subject: |
presne tak... _________________ -> Nokia Lumia 800 |
Posted: Fri Oct 27, 2006 6:49 am Post subject: |
screeny mi urobi len na neprijatych hovoroch a fotaku a sade inde to najprv vybehne do mainscreen a tam pipne aurobi fotku a na tych neprijatych hovoroch on normalne pocka, potom odfoti a az potom sa da do mainscreen a ine talcitka nejdu skoro nikde kde by som mohol dat spustanie screenshoteru
cim to je? neviete? |
mart22 elfmaster
56669.28 SMM
Posted: Fri Oct 27, 2006 10:46 am Post subject: |
mart22 wrote: | já mám screenshooter nastavený na keysequencer tak to nikam nevyhazuje |
to je super a nevies ci je niekde nato navod? ja neviem ako to funguje  |
EidzEm VIP
5862.50 SMM
D4X (o(^^)o)
Posted: Fri Oct 27, 2006 11:18 am Post subject: |
jo takle mno tak mmnt napisu tam navod jak rozjet screenshooter na keysequencer v2  _________________ -> Nokia Lumia 800 |
