:: View topic - Diskusia o elfoch pre telefóny Sgold3
Goto page Previous  1, 2, 3, 4, 5 ... 11, 12, 13  Next
JeyJeyko
PostPosted: Mon Feb 19, 2007 4:19 pm    Post subject: Reply with quote
idem s tym este nieco poskusat...
hmm keby som vedel rozbehnut ElfPack na fw 38 tak bezvahania nan prebehnem Crying or Very sad
S8->M35i+kabel->CX75+IRDA,RS-MMC 512Mb->EL71+microSD 512MB,DK-1
fw:45 ElfLoader2
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Thu Mar 01, 2007 12:09 pm    Post subject: Reply with quote
Nove FL pre EL71fw41
>Daruj krv<
JeyJeyko
PostPosted: Sat Mar 03, 2007 9:02 pm    Post subject: Reply with quote
To SMenu mi na mojom telefone vizera presne tak isto ako chlapikovi co dal screeny na tomto linku uplne dole http://www.forum.allsiemens.com/viewtopic.php?t=42184&start=285
Popis:Ked to SMenu spustim tak ono vizera normalne,ale pozadie mi nejak zhovadi...
btw.Tie nove FL mi nejdu aplikovat,s niecim mi to koliduje,ale v telefone mam iba elfpack.To ho mam vyhodit?
fw:45 ElfLoader2
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Mon Mar 05, 2007 2:41 pm    Post subject: Reply with quote
Elfpack obsahuje FL tak vyhod len tie. A tu su nove.
>Daruj krv<
JeyJeyko
PostPosted: Mon Mar 05, 2007 3:46 pm    Post subject: Reply with quote
Dukuuuu ty si Boh Very Happy Very Happy Ododnes ta ta budem vyznavat Very Happy Very Happy Very Happy
Diky ti moc,tie nove kniznice pomohly,konecne mi to fachci....
Este jedna mala question:To menu ma byt vidno na ploche aj ked ho nemam otvorene ("rozrolovane")?
fw:45 ElfLoader2
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Mon Mar 05, 2007 3:53 pm    Post subject: Reply with quote
Laughing Nemas za co wink
Ked nie je otvorene tak ho nema byt vidno
>Daruj krv<
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Wed Mar 07, 2007 3:13 pm    Post subject: Reply with quote
ElfPack 2.2 pre EL71fw38
>Daruj krv<
JeyJeyko
PostPosted: Tue Mar 13, 2007 5:37 pm    Post subject: Reply with quote
Zdravim vsetkych...
Trochu som sa nudil tak som spravil taky maly CSMlist pre EL71fw45
dal som ho tu
Je to prvy CSM co som spravil,tak to ma male muchy...
Duku ty si robil to CSM pre EL71fw41 v Smeltery?Tam je na to nejaka fci?
fw:45 ElfLoader2
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Tue Mar 13, 2007 6:24 pm    Post subject: Reply with quote
Nie, robil som ho rucne v TEDe. Smelter akurat vypise vsetky CSM adresy.
>Daruj krv<
JeyJeyko
PostPosted: Tue Mar 13, 2007 6:27 pm    Post subject: Reply with quote
a nevies ci sa uz daju niekde stiahnut tie entrypoints pre Smenu?Alebo sa daju nejako zistit?
fw:45 ElfLoader2
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Tue Mar 13, 2007 11:05 pm    Post subject: Reply with quote
Nevidel som ich zatial nikde. Daju sa zistit jednoducho wink
Otvor si vo WinHexe FF a chod do offsetu 8429B0 (pre EL71v45)
Tam su nazvy funkcii a za kazdym nazvom su tie entrypointy, ktore treba odpisat zozadu po dvojiciach, napr. ALARM_CLOCK - 49586FA0, takze entrypoint bude A06F5849.
Dufam ze som to napisal zrozumitelne Smile
>Daruj krv<
JeyJeyko
PostPosted: Wed Mar 14, 2007 4:03 pm    Post subject: Reply with quote
Napisal si to naprosto zrozumitelne wink Diky
Len mi trosku trvalo sa zorientovat,lebo ja som isiel na ten offset co si pisal
(8429B0) a tam to nezacinalo Eh? ,ale potom som dal vyhladat ten jeden entrypoint co si tu hodil,tak som to nasiel Very Happy Mne sa to zacina od offsetu
7C4930
Tak dik moc,zasa som o nieco mudrejsi Very Happy
Edit:Nachadza sa tam aj entrypoint pre vypnutie telefonu?Nejak to tam nemozem najst Confused
fw:45 ElfLoader2
mart22
elfmaster
elfmaster
56669.28 SMM
PostPosted: Wed Apr 11, 2007 7:28 pm    Post subject: Reply with quote
xtask 2.0 sk: nevíte jakou klávesou se spustí???
Sefinko
elfmaster
elfmaster
Location: Strážske (Okolie) Telefon: CSL65v53 EL71v45 + 1GB Kingston (c) Benlux
6980.53 SMM
PostPosted: Wed Apr 11, 2007 7:36 pm    Post subject: Reply with quote
Na EL71 sa spusta tlacidlom "fast dialing key" a na E71 by mal ist dlhym pridrzanim tlacidla na znizenie hlasitosti...
Duku
uživatel roka 2008
uživatel roka 2008
Phone: EL71v45
28.71 SMM
PostPosted: Mon Apr 30, 2007 10:03 pm    Post subject: Reply with quote
Neviem ci ta to este zaujima...vsimol som si to az teraz ked som nieco hladal. Entrypoint pre vypnutie aj restart je vo FL.
>Daruj krv<
Page 4 of 13
