:: View topic - HASH: ?
HASH: ?
vangelm
PostPosted: Sat Apr 14, 2007 1:56 pm    Post subject: HASH: ? Reply with quote
chalani, stretli ste sa niekedy s tymto:
Getting Information:
Model: SIEMENS EL71 45 lg4
Phone is in "Normal Mode". SecurityStatus: "FactoryMode"
IMEI: 358941004334762
HWID: 407
Attention: Charge Accumulator!
Accumulator Voltage: 3664 mV.
Code(05): OTP is Closed for write
Code(09): BootKEY is stored in EEPROM
Code(0D): Keys is stored in BCORE
Code(13): Full access to BFC functions
Code(15): Full mode (not SC)
Code(19): The control is On
Code(1F): E71 or EL71sw41(Block 5468)
EELITE Info: free buffer 186208 bytes, free at all 206240 bytes, free for deleted 206240 bytes.
EEFULL Info: free buffer 160544 bytes, free at all 466272 bytes, free for deleted 204192 bytes.
MAP info: Date: 14/09/06, Variant: A 976, Std-Map/SW: 1/13, D-Map/Prov.: 101/61
Factory (OTP) IMEI: 358941004334762 - matches to flash data.
ESN: 0C316A38
HASH: ?
BKEY in 5468 = "X" CE946681BD97DF4555A816C4BA43CC51
SKEY in 5122 = "X" 74549286
Minimum number of firmware: 13.
Bcore ID: 0300, version: main_1.0_V8".
Phone operated: 1341799 sec.. Total Talk time: 36002 sec.
FlashID(1) - Manufact. code:0020 (ST), type: 8819. DisplayID(1,65): Sharp Sharp LHH9168.
Ako je mozne, ze mam pri hash otaznik???
Skusal som aj obnovu FF aj s BCORE a nic...
Hash je aj niekde ulozeny? alebo sa to neda prepisat?
mart22
elfmaster
elfmaster
56669.28 SMM
PostPosted: Sat Apr 14, 2007 2:01 pm    Post subject: Reply with quote
hash je uložený(minimálně) v bootcore na adrese 3E400 tudíž se dá přepsat (zatím jediná cesta u e71 kromě koupení od jednoha Rusa) 8)
Pokud telefon funguje v pořádku a jde patchovat tak bych to neřešil.
vangelm
PostPosted: Sat Apr 14, 2007 2:49 pm    Post subject: Reply with quote
Vsetko funguje OK, tak si teda necham poradit a kaslem na to, ale je zaujimave, ze aj po obnove zo zalohy je to v takomto stave...
