:: View topic - Nápady na elfy
Nápady na elfy
Goto page Previous  1, 2, 3 ... 8, 9, 10, 11, 12  Next
BoSS_631
0.10 SMM
PostPosted: Wed Nov 21, 2007 11:51 pm    Post subject: Reply with quote
No ja rozmyslam o elfe ktory by urobil z telefonu BT hands-free pre skype alebo iny VoIP software.
Mozno nieco sam skusim ale zatial mam s65 z FW12 :D od pomaranca, takze ak to prezije mobil po tom co mi dorazi kabel z hong kongu :D (hlavne ak to bude ten co hlasali :D) :mrgreen: :mrgreen:
PostPosted: Thu Nov 22, 2007 6:50 pm    Post subject: Reply with quote
hmmm neviem ci je to mozne ,.ale asik by to mobil nezvladal ,. ale pomocou elfu prenasat video do pc ., ale live ,. akowebkamera Wink
drp
Phone: m65,se w610
31463.96 SMM
PostPosted: Fri Nov 23, 2007 7:17 am    Post subject: ELf aby by lfotak nas celi displej. Reply with quote
Sel by udelat elf aby byl fotak roztahnuty na celim dospleji?
mart22
elfmaster
elfmaster
56669.28 SMM
PostPosted: Fri Nov 23, 2007 8:07 am    Post subject: Reply with quote
některý věci elfama udělat nejdou
BoSS_631
0.10 SMM
PostPosted: Fri Nov 23, 2007 5:42 pm    Post subject: Reply with quote
Zaujimave, vravis mi ze by mobil nedokazal prenasat hlas do pc cez BT ale o webkamere nepochybujes? Very Happy
SE C905
<a href="http://www.penzionorava.eu">
Hladas ubytovanie na orave?</a>
MuF123
151.74 SMM
PostPosted: Sat Nov 24, 2007 12:42 pm    Post subject: Reply with quote
webkamera by bola nepouzitelna (bud male rozlisenie alebo 0.2FPS). ide to spravit uz aj teraz (bez elfu), ale ide o to ze je potrebne spravit driver/software na emulaciu webkamery a stahovania dat z mobilu.
HTC Wizard Tuning - http://www.youtube.com/watch?v=ethB7XaeFz4
Rfx64
89.44 SMM
PostPosted: Sat Nov 24, 2007 9:14 pm    Post subject: Webkamera Reply with quote
Jeden taky freeware software pouzivam na pripojenie miniDV kamery so SKYPE. Vola sa SplitCam a robi nieco ako virtualne rozhranie. Bez toho softu je miniDV kamera so SKYPE nepouzitelna. Mozno niekto zbehly raz najde sposob ako to vyuzit aj na prepojenie mobilu s PC a vyuzit tym mobil ako nudzovu kameru...
Nokia 1611, 2110i, 3310, MotorolaD520, Alcatel301, Ericsson 628, 688,1018, T10, Siemens C35, M50; S75: FW 47, FFSinit 40, MAP 47, factory mode, Elfbian 2.3, DCA-540+nabíjanie vlastná výroba, DCA-510 s vypínateľným nabíjaním z www.kabelmanie.sk, 2GB Kingstone DV, Nokia 6120 Classic 4GB, GPS EVOLVE, SE P990i 4GB
nerow
tuner
tuner
8011.36 SMM
PostPosted: Sun Nov 25, 2007 11:01 pm    Post subject: Reply with quote
Hodila by se elf klávesnice s podporou png, která se vysune kdekoliv v telefonu po stlačení nastavené klávesy Very Happy to by bylo dost dobrý hlavně na EL71, jelikož mě se pokaždé nechce vysouvat klávesnice...mohlí by tam být veškerý písmne a-ž, znaky apod jako je to ve WM
mart22
elfmaster
elfmaster
56669.28 SMM
PostPosted: Mon Nov 26, 2007 7:52 pm    Post subject: Reply with quote
jednodušší je vysunout tu klávesnici než napsat ten elf Shame on you
nerow
tuner
tuner
8011.36 SMM
PostPosted: Mon Nov 26, 2007 8:03 pm    Post subject: Reply with quote
samozdrejmě ze vysunutí samotné klávesnice je jednodussi nez napsat samotny elf, ale lidi by to na elku urcite vyuzili...
jinak nedokázal by nekdo upravit sMenu(nejlepe verzi 0.81 nebo 0.84), tak aby slo spustit i mimo MS?
dubacik22
67.00 SMM
PostPosted: Thu Nov 29, 2007 8:22 pm    Post subject: Reply with quote
nerow wrote:
a co kompletní elfový menu?Spustili by jste elf, a vybehlo vy vam Menu jako jste zvykli, akorát že by ikony byly jako png a v bcfg by se dala nastavit pozice ikon dle libosti...dále třeba by bylo nastaveni pro filesystem....hlavně třeba jako aby to bralo fonty z extra infa..nastavili by jste si jaky font bude u popisku dole apod...dale treba jestli ikony maji byt treba 3x4 nebo pod sebou a v jakým rozlišení to by ovlivonovalo kolik to bude zobrazovat radku v filesystemu...samozdrejme elf by musel vyuzivat theme...takže by se museli v bcfg nastavit adresy potrebnych obrázku...a vysledek by bylo kompletní menu dle predstav...myslim že by to hlavně využili na elku, kde jsou fonty vetsi nez mrakodrap a všecho proste velké
vaaaaaaav... ti rusaci su proste super.... namiesto zloziteho programu na otvaranie png a aj to len v 8-bitovych farbach som nasiel jednu funkciu, ktora mi dokaze rozlustit png v 16-bitoch aj s alfou.. takze zaklad menu by som mal... vykrelujem pozadie a ikonky, nastavujem pozicie ikoniek, kurzora a poradie vykreslovania.. este chcem vediet ako urobit nieco ako mc.. ale grafickejsie prepracovat..a este musim pomachrovat... kuknite na popis...
.... psicek to uz ma nasalame...
elf hra kocky
nerow
tuner
tuner
8011.36 SMM
PostPosted: Sun Dec 02, 2007 1:19 pm    Post subject: Reply with quote
jen tak dál pokračuj..jinak nesehanl bys sis pls zdroják od elfu extra info aby jsi mohl to toho elfu co děláš zaclenit png fonty? wink klidně ti ho neseznu
jinak k tomu MC...mohl by jsi použít MC 1.0 dat do nej podporu png fotnu, hrafiku dat jako png..tzn horni lista, vybrana polozka a treba do bcfg dat kolik se ma zobrazovat radku, to pak bude zalezet jak velky fonty budes mit nastaveny...
PostPosted: Sun Dec 02, 2007 1:42 pm    Post subject: Reply with quote
to som pisal k sebe .a nie tebe ,.,. ze neviem ci by to slo ,. som pochyboval o tej webke Very Happy,. len ty si si to zle vysvetlil Very Happy
dubacik22
67.00 SMM
PostPosted: Mon Dec 03, 2007 6:22 pm    Post subject: Reply with quote
hmmm... s tymi fontami je to dobry napad, ale predsa by bolo lepsie tam pouzit fonty ake su napr. v tede alebo edite nez png..... tam sa bude dat jednoduchsie nastavit farba nez v kazdom png-cku osobitne...ale tusim to takto funguje aj v tom extrainfe.. a nikde ho tu nevidim.. kde sa da zohnat??? a potom ten mc tu verziu.. to je nejaka starsia??? rad by som zohnal zdrojak nakej uplne starej... lebo ta nova je pre amatera ako ja velmi zlozita Crying or Very sad a tedu by sa aj dalo pochopit, aspon vymisliet sposob ako pouzivat tie fonty, ale zmena farieb a polopriehladnost by mi robila problemy... ten zdrojak extrainfa by som uvital....
elf hra kocky
nerow
tuner
tuner
8011.36 SMM
PostPosted: Mon Dec 03, 2007 6:58 pm    Post subject: Reply with quote
ok tak ja ti ten zdrojak sezenu..jinak k tem fontum, udelej spis ty png hlavne z duvodu ze si kazdej udela jaky chce fost v jakykoliv velikost apod..jinak existuje program font2png kde si behem par vterin udelas jaky chces fonty v jaky-koliv barve
Page 9 of 12
