:: View topic - "DCA-110" od gsmcables v prodeji
Goto page Previous  1, 2, 3 ... , 9, 10, 11  Next
PostPosted: Thu Nov 13, 2008 6:11 pm    Post subject: Reply with quote
lenže ty ho mas zrejme original ,.,. ale ja mam len bastlenu verziu co som zbuchal za pol hodinu Mr. Green
tak chcem vediet ci je dobra ci zla kedze papua šlape v pohode Mr. Green
P4priX
128.03 SMM
PostPosted: Thu Nov 13, 2008 6:32 pm    Post subject: Reply with quote
Já mám taky přebastlenej DCA510 a mám na něm přepínač aby nabíjel nebo ne Mr. Green
PostPosted: Thu Nov 13, 2008 6:37 pm    Post subject: Reply with quote
a nabija ti tu EL71 alebo nie ? Rolling Eyes
lebo mne CX75 nabija aj ostatne na jedej koncovke ,.a druhu sm stoho vyviedol BQS a tam uz nenabija ten EL71 i ked zapojenie je spravne ,. Rolling Eyes
ale len 4pinove ako pisal mario Think
nofate
58.26 SMM
PostPosted: Sun Nov 16, 2008 2:46 pm    Post subject: Reply with quote
Hanni v tejto teme napisal (Posted: Sat Sep 23, 2006 7:25 pm)
mario_liptov v teme http://www.siemensmania.cz/forum/viewtopic.php?t=24208 napisal (Posted: Tue Aug 08, 2006 9:31 am)
DCA510.....Connector "old" Lumberg.....Connector "Nano" Lumberg
Pin2- GND..............1......................................Pin5
Pin1- Power...........3......................................Pin7
Pin3- TX.................5......................................Pin3
Pin4- RX.................6......................................Pin4
...cize tento obrazok
Takze 2 rozne zapojenia pri prerabani DCA 510 na DCA 110. Takze, ktore plati a ktore je zle? Diky.
CX 65 -> fw25->fw43->fw50->fw43; CL71; EL71 silver
PostPosted: Sun Nov 16, 2008 11:56 pm    Post subject: Reply with quote
ten hanniho obrazok je spravny .,.,. ten druhy kresleny je na kkt.
DCA-510 DCA-110 (boot-box)
Pin 1.............................pin 7 ............................. (power +)
pin 2.............................pin 5 ............................. ( zem , minus GND )
pin 3.............................pin 3 ............................. ( data , TX )
pin 4.............................pin 4 ............................. ( data , RX )
dodam zachvilku spravny obrazok Wink
nofate
58.26 SMM
PostPosted: Mon Nov 17, 2008 1:51 am    Post subject: Reply with quote
Super, diky. DCA 510 je doma uz roky, konektor pre EL71 objednany z e-shopu... a bude sa spajkovat Wink
PostPosted: Mon Nov 17, 2008 10:13 am    Post subject: Reply with quote
a kolko ta stal ten konektor ? ,.,. pretoze ja som kupil v nejakom vypredaji neoriginal datovy kabel DCA-140 ,.(60SK) ,. ani som ho neskusal ,.., len som odletoval konektor a supol ho do DCA-510 Mr. Green
i ked ten konektor mal obsadene len 4 piny ,.,.,ale zrovna tie co som potreboval Mr. Green
nofate
58.26 SMM
PostPosted: Mon Nov 17, 2008 10:24 am    Post subject: Reply with quote
99 sk so vsetkymi pinmi http://www.kabelmanie.sk/Konektor-pre-mobilny-telefon-BenQ-Siemens-A38--A58_g1068.html
P4priX
128.03 SMM
PostPosted: Mon Nov 17, 2008 12:12 pm    Post subject: Reply with quote
Jo, nabíjí normálně, ale když třeba nabíjím a vypnu nabíjení tak se telefon tváří jak když se pořád nabíjí Shocked Musím vytáhnout a zase zastrčit kabel a už pohoda. A když ho zase zapnu, tak taky nic, musím ho zas vytáhnout zastrčit a potom začne nabíjet Anxious
PostPosted: Mon Nov 17, 2008 12:14 pm    Post subject: Reply with quote
patous ., jaky mas kabel ?., original ? ,. kolko pinov mas pripojenych do mobilu ? Rolling Eyes
nofate
58.26 SMM
PostPosted: Mon Nov 24, 2008 8:20 pm    Post subject: Reply with quote
Spravil som si redukciu podla tejto schemy - s merakom som prekontroloval, vsetko OK, nepreraza pin do ineho pinu. Mobile Phone Manager 4.20.636.41 mi nechce mobil EL71 nacitat. COM port mam nastaveny urcite spravne. Neviete cim to je? Urcite je tato schema ta spravna? Lebo ako som spominal ( http://www.siemensmania.cz/forum/viewtopic.php?p=378031#377645 ) tak su na tomto fore 2 rozne schemy.
DarkLegion
1453.28 SMM
PostPosted: Mon Nov 24, 2008 8:55 pm    Post subject: Reply with quote
zapojenie je spravne...presne takto to mam aj ja a MPM a ani iny manager sa mi tiez nespoji s telefonom cez ten kabel
servisne operacie vsak idu v pohode...inak vsetko robim cez BT a sem tam vytiahnem z telefonu datovu kartu a stiahnem z nej fotky a na karte velke upratovanie
po pravde ani ja netusim preco nejdu datove operacie cez tu redukciu Anxious
SIEMENS VEČNE ZIVÝ
nofate
58.26 SMM
PostPosted: Mon Nov 24, 2008 9:18 pm    Post subject: Reply with quote
ok, vdaka. Uz som mobil spojil s Papuou, vygeneroval kody a odblokoval som ho. Bol blokovany na t-mobile.
PostPosted: Mon Nov 24, 2008 9:24 pm    Post subject: Reply with quote
mne tiez cez ten boot-box nejde MPM ani nic ine ,.., len V-Klay a papua Rolling Eyes
PostPosted: Tue Nov 25, 2008 11:23 am    Post subject: Reply with quote
Ak sa dobre pamätám, tak bolo spomínané, že Boot-Box ide len cez TC s pluginom. Mne ide tiež len s TC.
Page 10 of 11
