:: View topic - S65 problem foceni > chyba
TuX
PostPosted: Wed Dec 22, 2004 3:43 pm    Post subject: S65 problem foceni > chyba Reply with quote
kdyz vyfotim fotku na S65 a pak ji dam vymazat tak se chvili neco deje a pak mi to napise : "Vyskytla se chyba" to odkliknu, zprava se vymaze pak pustim znova kameru a napise mi to znova "Vyskytla se chyba" odkliknu to a fotim dal, pekne me to sere....nevite co s tim ? nechci prehravat znova firmware ani fullflash Razz
Siemens Forever ! Smile
Siemens S65 ||| ???SX1???
FW 16 > 25 + patche Wink
[email protected]
oookoook
veterán
veterán
PostPosted: Wed Dec 22, 2004 6:21 pm    Post subject: Reply with quote
Sakra, tohle delal na CX65 fw5... To, ze to dela na esku fw25 je docela divny... Nemuze to byt nejakym patchem???
Oook Oook!
TuX
PostPosted: Wed Dec 22, 2004 6:26 pm    Post subject: Reply with quote
kdybych vedel ze je to patchem tak ten patch odstranim a je to v poho zejo, jenze ja to nevim...a zkouset vsech 20 patchu co mam v telefonu se mi moc nechce....
[email protected]
oookoook
veterán
veterán
PostPosted: Wed Dec 22, 2004 6:42 pm    Post subject: Reply with quote
No stacilo by poslat to jenom dvakrat... wink Ale driv ti to nedelalo, ne? Nedokazu si predstavit, jak bys to mohl spravit bez novyho fw, zruseni patchu nebo ff... Jeste by mozna nekoho zajimalo, jestli se ti ta fotka smaze i pres tu hlasku nebo jestli tam zustane.
Oook Oook!
TuX
PostPosted: Wed Dec 22, 2004 7:06 pm    Post subject: Reply with quote
huh, nakej omyl...
jo smaze se to ale sere me to, mam dojem ze sem to nahore psal...
[email protected]
oookoook
veterán
veterán
PostPosted: Wed Dec 22, 2004 7:11 pm    Post subject: Reply with quote
Napsal jsi tam "zprava se vymaze". Moc jsem nevedel, co to ma znamenat...
Oook Oook!
TuX
PostPosted: Wed Dec 22, 2004 8:48 pm    Post subject: Reply with quote
tam mela bejt fotka no, respektive video...
[email protected]
MartinS65
PostPosted: Thu Dec 23, 2004 12:11 am    Post subject: Re: S65 problem foceni > chyba Reply with quote
Tohle mi dela porad S65-FW origos 11, pak 14 a ted 25 a zadne patche. Nekdy se nemohu vubec dostat k fotaku, protoze : "Vyskytla se chyba", nemohu kopirovat na kartu, protoze: "Vyskytla se chyba" nebo: Chyba v profilu ... Taky me to pekne s...
........... a taky bych rad vedel, co s tim ... kazde kopirovani na kartu konci po skopirovani hlaskou o chybe v profilu.... kartu jsem uz smazal, preformatoval a stale stejny vysledek ...
TuX
PostPosted: Thu Dec 23, 2004 11:30 am    Post subject: Re: S65 problem foceni > chyba Reply with quote
hmm :/ tak to asi nezbejva nez doufat na new FW Razz
[email protected]
oookoook
veterán
veterán
PostPosted: Thu Dec 23, 2004 11:46 am    Post subject: Reply with quote
A nebylo by lepsi to reklamovat? Normalni chovani to rozhodne neni...
Oook Oook!
girik
PostPosted: Fri Jul 14, 2006 8:16 pm    Post subject: Reply with quote
videl bych to na zmenu fw, podle me to patche nedelaji. Confused
datluji s radosti ve tvari..
ajko
PostPosted: Fri Jul 14, 2006 8:19 pm    Post subject: Reply with quote
otvoril si 2 roky staru temu Applause
to je tu na SM niaky novy trend? uz asi treti clovek co otvara uplne temu od veci Anxious
mam chut si otvorit niaku temu aj ja
alkaba
10903.00 SMM
PostPosted: Fri Jul 14, 2006 8:20 pm    Post subject: Reply with quote
Děláš si srandu?! Rolling Eyes Odpovídat na 2roky starý topic... Brick wall
»HTC Rose S740 with WM 6.5.3
»HP iPaq 514 with WM6.5.3
»Siemens C65
