:: View topic - Mrtve CXT65
Mrtve CXT65
PostPosted: Sun Mar 13, 2011 10:52 am    Post subject: Mrtve CXT65 Reply with quote
Do ruky sa mi dostal Siemens CXT65. Mobil nejde vobec zapnut(nic sa nestane, ani PX), s PC tiez nechce komunikovat.
PapuaUtils 1.1.1b:
Code:
Boot in "Service mode"...
Press RED key (Power ON)!
Auto Ignition...
Transfer boot...
Boot Not loaded!
Boot in "Normal mode"...
Auto Ignition...
Transfer boot...
Boot Not loaded!
Viete niekto pomoct? Zeby to bol HW problem?
PostPosted: Sun Mar 13, 2011 12:30 pm    Post subject: Reply with quote
ja bych prepalil BCORE , a potom by sa mal chytit , ak by ti to nešlo skus zaškrtnuť aj chaos bot
PostPosted: Sun Mar 13, 2011 1:05 pm    Post subject: Reply with quote
BCORE som este neprehraval. Ako sa prehrava?
Tipujem ze to bude v papua zalozka Flash. Co treba vsetko zaskrtnut?
 papua.png | Description: Papua-Flash | Filename: papua.png | Filesize: 25.5 KB | Downloaded: 421 Time(s)
PostPosted: Sun Mar 13, 2011 2:05 pm    Post subject: Reply with quote
save info
make backup
pause
new bcore
a do the job
alebo skus ak by to nešlo aj ten chaos bot zaškrtnuť ...
hlavne si vyplň spravne udaje čo sa tyka HWID a pod.
14311.82 SMM
PostPosted: Sun Mar 13, 2011 2:11 pm    Post subject: Reply with quote
Držím palce Pray
Doma mám zopár mŕtvoliek, čo nejde naplno oživiť a ak, tak na niekoľko sekúnd, aj o hw siemens platí, že nič nie je večné Think
PostPosted: Sun Mar 13, 2011 2:37 pm    Post subject: Reply with quote
zatial neuspesne:
Code:
Auto Ignition...
Transfer boot...
Boot not loaded!
Invalid BootKEY or not properly joined TP!!
Boot released.
to iste aj ked som zaskrtol chaos boot
//EDIT: TP nemam
nejake napady?
PostPosted: Sun Mar 13, 2011 10:23 pm    Post subject: Reply with quote
vies ako sa robí TP ?
PostPosted: Wed Mar 16, 2011 10:46 am    Post subject: Reply with quote
tak trochu: viem ze sa maju spojit dane kontakty. ale neviem ci musia byt spojene stale, alebo ci to staci kym sa spoji s papua utils.
PostPosted: Thu Mar 17, 2011 12:06 am    Post subject: Reply with quote
ja som to robil lne raz na SX1 , a neviem ako na CX65 ale navod najdeš na SM snad
PostPosted: Thu Mar 17, 2011 11:24 am    Post subject: Reply with quote
OK, TP som spravil podla http://www.siemensmania.cz/content.php?id=409 ale BCORE sa mi nepodarilo stale nahrat:
Code:
Auto Ignition...
Transfer boot...
BOOT is loaded...
Pause 2 sec...
Getting Information...
Unknown flash type (ID:F004) or:
1) Malfunctioning TP.
2) Not all contacts in PMB and Flash.
3) Defective flash-memory.
4) Defective another part of phone.
5) Defective cable (adapter).
Boot released.
TP som spravil podla navodu, kabel mam dobry.
