:: View topic - WAVy pre x65
WAVy pre x65
Goto page Previous  1, 2
Mio
10930.24 SMM
PostPosted: Fri Feb 18, 2005 2:49 am    Post subject: Reply with quote
Jak rika servisni manual:
• ADPCM encoder (8 kHz sampling frequency), cannot run in parallel to a speech codec
• ADPCM decoder (8 kHz and 16 kHz sampling frequency), cannot run in parallel to a speech codec
Takze dekoder by mel zvladat AD-PCM 16kHz 4,8,16 bitu ovsem pouze ve spravnem formatu, a to tak ze musi odpovidat hlavicka upravenemu formatu AD-PCM.
N95-8GB
CX65-ka
PostPosted: Fri Feb 18, 2005 3:32 pm    Post subject: Reply with quote
Taka otazocka :: nemoze byt AMR vo vyssej kvalite ako WAV ?? Ze by sa to niekde dalo do toho skomprimovat ? Neviete o tom nieco ci sa to neda urobit kvalitnejsie (lepsi zvuk) ako tie WAV-ky ??
I have CX 65
oookoook
veterán
veterán
PostPosted: Fri Feb 18, 2005 5:30 pm    Post subject: Reply with quote
jj, ale tech 16bitu je komprimovanejch na 4...
Oook Oook!
oookoook
veterán
veterán
PostPosted: Fri Feb 18, 2005 5:32 pm    Post subject: Reply with quote
Bonfire wrote:
oookoook: uz se kvuli tomu hadame podruhe. Pak nekde dam na web rozdil jak si vzpomenu
Jojo, uz podruhe. Jeste jednou se zeptam - ses si jistej tema 16 bitama? CX65 16 neprehrava, jenom 8, a potom by sedelo i to, ze ty soubory jsou stejne velky. Ja muzu taky dat na net porovnat svoje PCM 8khz, 16bit (kterej ale mobil neprehraje) a IMA ADPCM 16khz, 4bit. Jenom se musim dostat k jinymu pocitaci...
A nerikal bych tomu hadka, to je moc silny slovo... Vic se mne libi treba sdelovani zkusenosti.. wink
Oook Oook!
oookoook
veterán
veterán
PostPosted: Fri Feb 18, 2005 6:14 pm    Post subject: Reply with quote
Tak tady to je:
http://www.ekodilna.cz/opinion-PCM-8-16.wav
http://www.ekodilna.cz/opinion-IMA-16-4.wav
Oook Oook!
Mio
10930.24 SMM
PostPosted: Sun Feb 20, 2005 9:58 pm    Post subject: Reply with quote
No AMR ma nejlepsi kvalitu 12.2 kbit/sec (Nokia Multimedia converter PRO 2.0), nevim jakej ma kompresni pomer, ale wav jak tady pisou 16kHz * 4bit = 64kbit/sec je asi urcite kvalitnejsiá, bohuzel i podstatne vetsi.
JInak jestli jde na jakekoli sample rate 16bit, tak by mela jit i na 16kHz 16bit, ten D/A prevodnik je omezen jen poctem bitu, procesor pracuje s propustnosti 1,7Mbit (omezeno sbernici), 16kHz*16bit = 256kbit/sec, jestli je to omezeno tak to bude softwarova zalezitost.
N95-8GB
oookoook
veterán
veterán
PostPosted: Sun Feb 20, 2005 10:06 pm    Post subject: Reply with quote
No jasne, IMA ADPCM zvlada 16khz i 8khz, v PCM CX65 jenom 8khz. Bude to softwarova zalezitost. BTW kdyz prevedes PCM 8khz 8bit v Zaznamu zvuku ve Windows, neprehrajes ani to - ty windowsovy kodeky to prevadi nejak blbe, potrebujes program, kterej ma vlastni...
Oook Oook!
Mio
10930.24 SMM
PostPosted: Mon Feb 21, 2005 12:19 am    Post subject: Reply with quote
Sorry ale utika mi souvislost s tim mym prispevkem muzes mi objasnit cos tim chtel rict? Nepsal jsem ani o formatu ani o kodeku, ale o sample rate a bitrate. A softwarova zalezitost jsem myslem FW telefonu kterej si hlida format prehravaneho souboru, nebot HW podporu ocividne ma.
N95-8GB
McKenics
PostPosted: Mon Feb 21, 2005 2:01 am    Post subject: Reply with quote
ja si upravim mp3 v softe > > > Audacity (inac fayn program...malu, jednoduchy a pritom ma kopec efektov...) a dam ulozit ako wav (je tam aj zaujimava moznost > Exportovat vyber ako wav...) a potom tento wav len otvorim v SOX a dam konvertnut na 16.000 kHz a je to...vsetko pekne bavi (PS: mam CX65 s FW16)
bombbob
PostPosted: Mon Feb 21, 2005 8:46 am    Post subject: Reply with quote
Já už dlouho používám na editaci audio souborů iMagic Audio Editor
Ke stažení např: http://www.slunecnice.cz/product/iMagic-Audio-Editor/
Umí otevřít a uložit všechny možné audio formáty včetně IMA ADPCM a na tvoření WAVů do mobilu je jak dělanej. Máte všechno v jednom žádný zbytečný používání více programů.
oookoook
veterán
veterán
PostPosted: Mon Feb 21, 2005 3:16 pm    Post subject: Reply with quote
Proste sice 16/16 zvlada, ale preci jenom je to kodovany ruznejma kodekama a proste ne kazdej kodek to dokaze rozlustit. Ve fw zrejme neni podporovany PCM 16khz 16bitu, ale IMA 16khz 4 (16) bit uz jo. Kdyz "spatne" zakodujes PCM 8khz 8bit, taky to telefon neprehraje. Nemam uplne jasno, co znamena hardwarova podpora, ale predstavoval bych si to nejak tak, ze fw dostane soubor a zpracuje ten wav, "vytvorenej" urcitym kodekem, na nejaky "univerzalni" data, ktery pak sezere procesor. A tyhle data budou stejny pro IMA i PCM, jenze ne vechno proste podporuje ten fw. Doufam, ze to aspon trochu dava smysl... Smile
Oook Oook!
Mio
10930.24 SMM
PostPosted: Mon Feb 21, 2005 11:06 pm    Post subject: Reply with quote
oookoook:
Aha, tak abych ti to upresnil, format wav se lisi pouze hlavickou souboru, vlastni data nejsou nijak komprimovany, takze nejsou v zadnem kodeku, v hlavicce je uvedeny parametry a kvalita daneho zvuku. Ruzne typy PCM se lisi prave jen hlavickou souboru.
HW podporou je A/D a D/A prevodnik, ten je limitovan kmitoctem na kterem pracuje a poctem bitu ktere zpracuje/prevede na hladinu analogoveho signalu v jednom taktu.
Podle manualu prevod zajistuje procak, ktery pracuje na 104MHz, a umi prevest zvuk 16bit, takze se spravnou hlavickou zpracuje 16kHz na 16 bitech. Neni k tomu ve FW potreba nic vaznejsiho, jen algorytmus ktery precte parametry a nasmeruje datovy tok na spravny vystup.
(dost jsem to zjednodusil takze me prosim nopravujte ani nedoplnujte)
N95-8GB
oookoook
veterán
veterán
PostPosted: Tue Feb 22, 2005 2:21 pm    Post subject: Reply with quote
Hm... Ale co ja vim, tak IMA ADPCM se vyznacuje tou kompresi (bezztratovou) 16b->4b... Takze to by potom nemohla byt ta data u ruznejch kodeku stejna, i kdyby obsahovala stejnou informaci... Coz teda obsahujou - PCM 8khz 16 bit zni uplne stejne jako IMA 8khz 4bit.
Oook Oook!
Stanley497
PostPosted: Tue Feb 22, 2005 4:26 pm    Post subject: Reply with quote
musis dat 8bit mono
oookoook
veterán
veterán
PostPosted: Tue Feb 22, 2005 4:29 pm    Post subject: Reply with quote
Stanley497 wrote:
musis dat 8bit mono
Promin, ale nezda se ti, ze mluvis trochu z cesty? Smile Tohle byla reakce na co?
Oook Oook!
Page 2 of 2
